bshanahan14rulz
DB: what's neat about laptop batteries, sometimes you can even pull data like how many cycles the cells have been through and when the pack was made from the laptop's battery "driver"
Help Support Candle Power Flashlight Forum
I'd question anything that depends on a momentary measurement to decide "good" or "bad". I can understand that a lithium cell (especially the common lithium-cobalt based chemistry) which has been discharged <2.5V and sitting there for a while, might be damaged beyond recovery. But that should not be decided by a simple voltage measurement.1. measure cell voltage. if it's less than 2.5v, throw it away.
IMHO it would be better to (try and) put a cell through at least 1 or more full charge/discharge cycles, and monitor how it behaves over time. If that behaviour shows far-out-of-normal parameters: discard. If that behavior shows far-below-nominal remaining capacity: discard. But if @ the start of the process it reads a much lower voltage than desired/expected: be patient, and see how it does further on.
-If you wanted to meet up, just PM me. I can dremel off the weld spots from the ends for you. Those little spots on the ends of the cell will chew up your light. Your light collection is $$$$$, and its worth the added effort. Heres what mine look like after dremeling...
Good job!!:twothumbs
Charge them up and see how they perform. Most Li-Ions are shipped with that voltage. Better for storage.
Bill
So, we've got 1733mAh batteries (as there were 3 parallel pairs). Does this help anyone?
I think you have that wrong. It should be 3S2P for that battery pack of 6 cells. The cells should be 3.7V 2600mAh cells.
As for the electronic cigarettes, most of them are just a resistance coil. Use your multimeter and measure it, then you can apply Ohms law. For instance, 2.2 Ohms, I = V/R, I = 4.2/2.2, = 1.9A. So your fully charged cell has a max drain of about 0.8C. With old cells, I tend to avoid going over 1C.
Could you help me out with the 3S2P? Am I interpreting correctly that you're saying 3 in series and 2 in parallel? Wouldn't that be 7 cells?
The reason I was thinking 3 parallel cells was due to the fact that all were connected the same and there were 3 wires running to the PCB (plus the ground). Not that I would complain about 2600mah cells rather than 1733, just trying to learn how you came to that conclusion.
3S2P means two parallel banks of 3 cells in series. http://img15.imageshack.us/img15/5479/3s2pultrafire18650prote.jpg
Maths, You have 6 cells, the individual cells will have to be either 3.6V or 3.7V. To get to 11.1V, 3 * 3.7 will get you that. The capacity of the pack is rated 5200mAh, the 3 remaining cells need to be in series as well in so the two banks will be in parallel. 5200 / 2 will give you 2600mAh .
The other factor is that no-one makes 18650 cells that are 1733mAh that I know of.
Since there are 4 wires running to the PCB, perhaps it should be called 2P3S?
2 cells connected in parallel, then connect 3 of it in series.
I have a very limited knowledge on this, but I think the capacity calculation stays the same.
Just a quick question, but does anyone happen to know which laptop battery packs are most likely to produce Sony cells?
Sony ones ..
For me, with the mystery cells I make sure that I don't draw more than 1C. I'm sure I've seen that logo on your cell somewhere but I don't remember where.
