I know that the INOVA X series has been around for at least a decade perhaps longer and don't even know if they are still in production. The most recent thread on CPF (via the "search" function) was 10 years ago so I'm thinking starting a new thread is acceptable 🤔.
I picked my X5 (green LED) up at a garage sale for $1 a few years ago. The issue with it was that the "twisty" tailcap had a tendency to be very loose in all but the "full on" position. It would go from the "momentary" position to the "full off" position just from movement in my pocket. This certainly made for a high level of unreliability when I wanted it to have one-hand functionality. My first solution was to place a section of rubber cut from a narrow bike inner tube over the junction between the tailcap and the body. Functionally, this worked but was hardly what one would call "elegant" and yes I believe many would consider the INOVA X5 to be "a more elegant light from a more civilized age" 😉. Anyway, I wasn't happy with that fix. I don't know if it was a design issue or a materials issue but the O-ring on the body no longer provided any resistance to rotation of the end cap. Not wishing to contact INOVA and wait for their solution (if any) I replaced the OEM O-ring with one with a larger x-sectional area. That definitely tightened things up! I applied a little silicone lube and now the "twisty" tailcap functions as it should 👍. I did spray some electrical contact cleaner inside the tailcap and ever-so-slightly scraped the contact ring on the body. This light functions perfectly now! To be completely honest, the "bubba" fix with the piece of inner tube worked but was very tacky 🙄.
Sovende
Sovende
