UCL lens for Dereelight ruined.
electric sheep
UK
Ordered the 28.6mm UCL lens knowing it would be half a mm to big. I then spent an hour taking the dia down on wet/dry until it fitted. Was just about to smooth the edge when my hand slipped and the unmasked lens slid across the paper. Many little scratches ruined the surface:eek: feel like an idiot, should have masked the lens again. Have another here and will try again when i have the energy.
Where did you order the lens from? Let us know if you can see any improvement.
Straight from UCL, i ordered two but the second is thicker and will take longer to reduce. Just cannot face it right now.
I feel your pain. I really wish someone would make a good lens for the DBS. Its really the only bad part of the light. I am on my second one for my V3 and its already trashed. ugh.
This is for the CL1H, if i mask it with scotch tape it should work. All i can do is try again.
Having no access to a light meter at the moment i can only go on comparative eyeballing. It does seem a cleaner brighter beam with the new lens. It certainly looks better front on as the new glass has a more gem like quality compared with the old one. Takes about 40 min to take the over size UCL down to a tight fit but i think it was worth it.
