N
Nerd
Okay, this probably doesn't deserve a place here. But I built this for fun. I had acutally plan to use it as a bicycle light or as a "flashlight" for macro photography (cast the light from overhead)
*In case you are wondering what's the blue patch at the back ground of the picture, it's 2 pieces of half used Energizer Photo Lithium 123s.
I had used a bread board, 56 5mm LEDs (sorted out for low Vf of below 3.5 volts @ 30ma), 56 pieces of 47 ohms resistors, all in parallel, using the resistor to limit the current.
I discovered that I can power this off a very much dead 123 battery, a full 123 battery, 2 123 batteries, 3 to 5 pieces of AA batteries in varaying levels of discharge.
The amazing thing is that the entire board of light works down to 50 ma of current draw and provides much much more light than a Arc AAA. (Given the number of 5mm leds used here, actually it's not too surprising) If I want 25 ma to each LED, it's 1.4 amps of current draw from the battery, which needs around 5 volts. Since as the battery voltage drops, the thing becomes more efficient
I'm willing to bet it would have run time ranging in hundreds of hours on 5 AAs. Don't ask about the run time on 4 D cells. /ubbthreads/images/graemlins/icon15.gif
Did I mention that I'm roughly better than a pre-schooler at soldering? /ubbthreads/images/graemlins/help.gif I find it pretty amazing that I manage to do it at all. I probably shouldn't show you the bottom side of the board. /ubbthreads/images/graemlins/tongue.gif
Some of you guys will most probably ask why don't I use a LS or a Lux 3? Simple, I don't want a point source light, I want a broad source of light that makes me very visible at night when I'm cycling. I gotta do somethign about the air resistance though. /ubbthreads/images/graemlins/icon15.gif
Beam shots? Comparism? Uh, it's not even dark here yet! It's only 3pm in the afternoon. /ubbthreads/images/graemlins/jpshakehead.gif
Plus I sold my ARC LSH-P some time ago. Lemme see if I can dig up some old beam shots. /ubbthreads/images/graemlins/grin.gif
Finally thanks for reading through my rambling and boring stuff, hope this post shows a whole new view 5mm LEDs as being useful for something. /ubbthreads/images/graemlins/wink.gif
