After a day of play, here are some more significnat findings about the UK100 Light Canon.
As mentioned earlier, when I compared it to the SL 35, it was only 90% as bright. I called UK this morning and got lucky; I was able to speak Jeff, the project manager for the Light Cannon.
Item
Each Light Cannon is hand focused to match the variations in the bulb. I you refer to YeeDude's picture of the "heat sink", notice the three phillips screws which are just like three legs of a tripod.
(wouldn't you know, my light was out of focus, but it ain't any more)
Item
NiMh batteries is what Underwater Kinetics would like to have offered as the power source for the Light Cannon, but due to "politics" within the organization, did not happen. In fact, if you notice, UK does not offer any NIMh batteries...."eventually we will have NiHm but we then need smart chargers etc." is what I was told.
Item
The cutoff voltage when the light will no longer run is between 4 and 5 volts. The ballast circuiit needs a minimum voltage of 6 point something volts to fire up the system.
Item
If the light is dropped from 5 feet onto a concrete surface, the bulb wil break. They have had no reports of any bulb damage when the lights have been packed in luggage, or for that matter, none have been returned as having been damaged in shipment. I was told they even dropped the light on carpet; no damage (not recommended though)
This light is so cool
