rlhess
OK, I still don't like it when numbers don't seem to add up with what I'm seeing...
I've got beam candlepower measurements down so that those numbers make some sense.
Back to the pine trees. I wouldn't expect the UK SL-6 to light them up as well as the SRTH Surefire Turbohead...and my expectations were met. The 9P with SOLA (as opposed to HOLA) doesn't do as well as the SL6 at the spot, but is much broader.
Here's the problem.
The SL6's spot is a LOT smaller than the SRTH.
There is little spill from the SL6 (no where near the coverage of the 9P SOLA (standard output lamp assembly -P90).
So why am I confused?
It's the LUMEN OUTPUT ratings now...
UK lists the SL6 as a 200 lumen light (actually, with data provided by UK, it lists as 201 lumens on Bright Guy's site).
The N2 is a 105 lumen lamp
The P90 is a 105 lumen lamp
Over their respective ranges, both 105 lumen SureFire lamp assemblies seem to give out more total light than the SL-6.
Thoughts?
Merry Christmas!
Richard
Here's the problem.
Thoughts?
Merry Christmas!
Richard
