mdocod said:
So it looks like the solution is simple, HO-9...
I can't say that I'm not tempted to go with an HO-9, but my rational side continues to remind me that it in no way furthers my goals in terms of the intended utility of the flashlight. As an emergency light, functionality is given the utmost weight - and replacing batteries should not be a significant issue unless the flashlight is used beyond what it was originally intended for.
mdocod said:
...same output/runtime/heat you have now, but rechargable.
Now, if there was some lumen gain and the remaining functionality decreased only slightly, then I could perhaps justify the switch. However, net lumens would stay the same with an HO-9, and runtime would decrease to 50 minutes from the 60 minutes provided by SureFire primaries (I do not want to bore out my SureFire, so I'd be using 2x17670s). I also have a suspicion that the HO-9 would derate faster than the 12V lamp. Beyond that, the hot-spot and flood would slightly decrease as smaller voltages go hand in hand with smaller filaments (LumensFactory explains this on their site); a 12V filament is longer than a 9V filament, all things being equal, and a longer filament corresponds to a bigger hotspot. Efficiency would slightly drop as well (again, see LumenFactory's website were they indicate that higher voltages correspond to higher lumens per watt), which would correspond to a slightly higher generation of heat.
All of this doesn't add up to much, but the reality remains that the beam comming from LumenFactory's 12V, 12 watt lamp will be just slightly better and last 20% longer that the beam comming from LumenFactory's 9V, 12 watt HO-9. The only reason that I would go for this would be to save on batteries, and the only reason I would want to save on batteries is if I was using my flashlight in more instances than just emergencies (more frequent use would of course use up the life of the bulb thus raising the possibility of it failing during an emergency). The only reason I can think of using this flashlight beyond emergencies is if I was playing with it in the backyard at night to admire the beam.
mdocod said:
enjoy your new addiction!
Thus, I would need to develop and then nurture a light fetish to justify switching to rechargeables. As tempting as this is, I just don't see myself, or want to see myself crossing that line. In any case, my Fenix P3D is just a little brighter than is appropriate for most tasks on its turbo setting, so I'll probably keep that as my "duty" light and the SureFire will sit in the drawer for emergencies. It will probably go in the gun-safe with the Glock 45 ACP I'm planning on getting at some point for home defense. After having considered all of the valuable input I have received, I still have to conclude that the "12P" setup I currently have configured matches the highest net functionality in its class (its class being compact, bright, good beam quality, cool in the hand, long running, highly reliable, low maintenance, indoor home defense), and I just can't bring myself to step down from that, if only just slightly. Though I am sticking with primaries for now, I do concede that it is likely that at some future point I will switch to rechargeables in my SureFire "12P," but only when doing so raises the net functionality of the flashlight.
***I am reminded of a childhood tale I had read as a boy. It told the story of an impoverished family that lived by the sea. Their young son fell ill, and they could not afford to hire a doctor for his treatment. They prayed to their God, asking for a miracle - the next day, the father fished the sea as usual, but came up with a miracle - a large oyster that housed a massive, beautiful pearl. Though the parents originally were ecstatic that they could now save their son with the money they would surely get for the pearl, their tale took a turn for the worse when they looked more and more to the value of the pearl - thus losing sight of what they really wanted. What I really wanted was something that would help me and my family stay safe - I don't want to loose sight of that and focus instead on the "pearl."***
