greenlight
My glow powder/paint order arrived Monday, and I was excited to test it out. The pouch of glow powder had 0% charge when I took it out of the box, and a quick blast of sunlight was all that was needed to charge it up. That's some bright glow powder. :candle:
I have other glow powder samples from glow inc. that I have been using. They work well. I wanted to see for myself whether this glow powder was visibly brighter than the old stuff, so I set up a time-lapse photography experiment to test the glow fade-out.
This experiment uses a canon A620. I don't have any light meters, so this is only a visual test to determine the relative brightness of the samples. After a while the glow was too faint, so I had to decrease the shutter speed to 15 seconds, and later I boosted the iso from 50 to 200. Take that into consideration when the apparent brightness changes in the photos. The test is only to determine whether the samples are still glowing, and which is brighter. I used Picasa editor to boost the brighness of the pics so the glow would be visible. This is Not a test to determine the fade time/rate of the glow powder. We are only observing relative brightness.
I have indicated the TOTAL time lapsed between the pics. The new glow powder is on the bottom left, in a packet with a label on it. The other samples are labled pl-7 and pl-9. I have no idea what they are.
00:00:01
00:00:01
00:00:15
00:01:36
00:05:08
00:07:17
00:08:38
00:09:21
00:14:24
00:16:10
00:17:05
My initial impression was that while the powder might be slightly brighter than the previous samples, it was tough for me to visually determine how much brighter. I was hoping that taking these photographs would show some brightness difference. It seems that as the glow fades, the relative brightness of the samples is more similar. By morning I was still able to faintly see the samples glowing, but so were other items in my house.
I have a feeling that the brightness rating for this product is measured the instant the lights are turned off. It might be twice as bright, but that might be only for the initial glow. As it fades, it just looks like any other fading glow powder.
My testing system was not very scientific. If you tested your glow powder samples and got a different result, please post here. I will do some more tests to see if I can determine the difference between the two samples. Maybe a blind test with the labels covered... I'll try to guess which is which. Testing glow powder by charging the packets may not give the best results. It's possible that the particles when suspended in a clear compound glow brighter with less powder than the old product. Maybe we'll get a test like that soon.
EDIT-- 4/6/07
Glow inc. confirmed the mixup and is working on a remedy/solution. Please be patient and stay tuned to find out the latest news about their new product.
00:00:01
00:00:01
00:00:15
00:01:36
00:05:08
00:07:17
00:08:38
00:09:21
00:14:24
00:16:10
00:17:05
EDIT-- 4/6/07
