kosPap
Greetings all!
Some days ago I received Ultrafire's 4-mode Cree Module. (from the Ultrafire-Shop though it is also available from DX)
http://www.newexcite.com/shop/index.php?main_page=product_info&cPath=15&products_id=117
http://www.dealextreme.com/details.dx/sku.7162
The module is rated for 3.6-9 volts by Ultrafire and I was able to verify it by placing it in a Surefire C3.
The module has no mode memory, so each tap brings you to the next one, and if you put the light off it will come up in the next mode when you fire it up again. Not that big an issue for me.
BUT what I did not like is its low output. A bit higher than a 3W T-bin module still not up to the market. There is a reason for this
In a Huntlight FT-01 and 2 Ultrafire WF-502B bodies amp readings where:
High: 300 mA
Medium: 240 mA
Low: 90 mA
Strobe: about 140 mA (it seems to me that strobe is a bit fast, definitely over 10hz)
In the Surefire C3 readings where: 220 / 110 / 80 mA.
In the latter case there was not a big (perceived) difference between the High and Medium mode.
Tint is bluish to purplish, still "whiter" than some Fenix Cree and Huntlight Luxeon offerings I have.
Also beam is more spottish than expected
Overall judgment will be made once I receive another 6V-compatible multimode module I am expecting from KD.
enjoy, Kostas
High: 300 mA
Medium: 240 mA
Low: 90 mA
enjoy, Kostas
