rizky_p
I bought 28mm Aspherical Lens(glass) from KD few months ago for different purpose. The lens diameter fits the front opening nicely like it made for it. It still using the original reflector, i have to think a way to remove the reflector and make the module sit tight inside the tube in order to get better result. it isnt as clean as maglite aspherical mod with the reflector removed but for a quick mod the result is surprisingly good.
A halo/corona present because of the original reflector is still in use
Underexposed
Standar Reflector
Standar Reflector+28mm Aspherical Lens
For those of you who wondering, the lens Protrudes the bezel at about 1mm. Yes it can stand on its head but not straight.
Thanks
Underexposed
Standar Reflector
Thanks
