Ultrafire Charger WF-139 questions
flashlight nut
New York
Need a little advice here. This is my first venture into 18650 rechargables. I purchased the ultrafire charger and 2 ultrafire 3.7 protected batteries from Battery Junction, so all are brand new.
I guess a should have researched this particular charger on this forum first but I am stuck with my purchase. The charger does not come with instructions so I have a couple of questions.
- The led lights on the charger are red when charging but flash green every second or so. Is this normal?
- How long does it take to fully charge the batteries?
- Can I leave the batteries charging over night without worring about the house burning down?
Sorry for the lack of basic knowledge but new to the flashlight world.
Thanks in advance for the help.
Paul
Paul
1) Im not quite sure whether mine flashes green but my red definitely flashes when charging, so it should be alright
2) Mine takes about 5-6 hours on a mostly discharged battery
3) Ultrafire chargers have a poor reputation, especially with some of my stock spoiling and all that. Yes but i have done that before
This is true, but everybody has to start somewhere. As king2penn said about their chargers, they're definitely not the best. This pretty much applies to everything else they offer, as well, including Li-Ion cells. They're pretty much "hit and miss", mostly "miss".
Yes. This is the charger pausing to check the cell's voltage during charging. I might add that this is not an approved method to charge Li-Ion cells, but won't go into that here.
I think king2penn covered that close enough. Charging time depends on the state of charge (SOC) of the cell, it's potential full capacity, the age of the cell, and other factors.
No!
The charging of Li-Ion cells for flashlight/torch use, differs greatly from charging your laptop, or cellphone. Laptops and cellphones have charging circuits designed specifically for the exact battery installed in them. The cells we use in flashlights vary enormously between manufacturers, capacities, exact formulation used in the specific cell, and other cell specific anomalies that the designers of even the very best chargers cannot take into consideration when designing the charger. For this reason when charging Li-Ion cells for flashlight use, one should NEVER leave the operation unattended, regardless of the quality of the charger being used. An unfavorable incident is unlikely, but the risk is still too great to consider doing otherwise.
In addition to reading, reading, and then reading some more, I would suggest that you check out the "Threads of Interest" sticky at the top of this Forum, as well as the "Smoke And Fire" thread for relevant information, as to the proper use and care of Li-Ion battery cells. A lack of basic knowledge can get you into real trouble. It is important to know and understand the differences between Li-Ion cells and other chemistries to properly use and care for them safely.
Dave
I wouldn't leave them charging overnight unsupervised. There are too many horror stories and too many youtube videos of exploding li-ion batteries that it's just not worth the risk. Overcharging is a REAL danger.
Mine take about 5-6 hrs on a mostly discharged 18650 as well. But you can actually calculate approximate charge time based on battery capacity and the charge output of the charger, which 450mA. So for a 2600mAh battery, do 2600/450 = 5.78hours. That'll give you a ballpark figure of how long it'll take to charge that particular battery.
The charger led will flash green and then go back to red when charging. When it flashes green, what it's actually doing is stopping the charge process and measuring the voltage of the battery to see if it's at charge capacity and then resumes charge if it's not. That limit should be 4.2v but some chargers voltage measurements are kind of off so some will charge a little over 4.2 (not too good for battery life) and some will charge a little under.
Yes... provided they stop flashing at 4.2V and turn solid green.
~1-5-2 hours tops for me... but then again I never fully deplete my cells.
NO... absolutely NO... NO repeated again for emphacis. While I have done this before (3-4 times on accident), its best not make it a habit.
Sure no prob.
If you go to-- lighthound ,,--Google-- LIGHTHOUND-----and go to batteries and carriers.. you will see sub titles --------click battery chargers ----------and the trustfire 139 is there.... and if you look around there- you will see( download manual). I just did it to be sure ..I have the same 139 ---- Its there go get it.. I checked for you.
If you dont find it let me know and I will Walk you through it, Mine also did not come with instructions, but LIGHTHOUND told me when I called them that The instructions,,,were on their site . so there I went... I did have to look around a bit to find it,,,, so I went back again now,, to do it again for you. Its there good luck..
Hmmmm.
Older revision of the WF-139 or a later one ?
Later ones stop charging , no trickle charge .
The issue is the way the charger charges , as to whether this is an issue or not ? I dont believe has been established .
Blaming the charger for damaging or shortening the lives of what may have been bad cells to begin with ?
A lot of the WF-139 stuff seem to be from the earlier models , mine is some 12 months old now , and I like it , it stops charging on completion , and I have not noticed any battery issues from using the WF-139 .
So the only thing I can think of , is U just need to make sure you have a later model , and not left over stock from a earlier revision of the WF-139 , since its these earlier models that earned a bad rep .
Thanks to all for the responses. As always, CPFers are top notch and always there to help. I will read the links suggested and go to Lighthound for the manual. And most important, NEVER leave the charger unattended.
NO!
The WF-139 is a basic, bare bones, charger. Reliability is spotty, at best. Often, it will continue to trickle charge the cells even when they are done. That's bad. It's the sort of charger that you you have to keep a constant eye on. (Key word being "constant.")
That's what I always do with mine, and I must admit that my sample is one of the better WF-139 chargers out there. When I pull the cells, they are hot. I always put them aside for 2 hours before using them. My Ultrafire charger is now a back-up one. The only charger out there that is worse is the DSD model.
If you plan on charging your cells very often, just spend the extra money on a quality charger, such as the Pila IBC model. If you're like me, and don't use rechargeable cells often; the WF-139 will get the job done. But just be sure not to let it out of your sight.
I did experience the blinking green light on my sample as well. It means your cells are not charging properly. Check to be sure the charger is properly plugged in. If the same thing keeps happening, it might mean your cells are crap. That's what happened to me. I replaced the cells with those from a better brand, and the blinking green light stopped. My charger has worked normally since then. Red, when the cells are tossed on. Follwed by green, when they are fully charged. Then again, blinking green might mean there's something wrong with the charger itself. In my case, it was an issue with the cells.
Mine works fine. I've left it overnight, and on a few occassions, several days.
I know it's not smart, but so far, no worries. Cells are NEVER hot, and at worst, barely warm while the light is red. When the light goes green and I pull them out, they are at room temp.
Never measured a fresh off the toaster cell above 4.2 volts. I only use protected TrustFire, UltraFire, and Tenergy cells though.
EDIT: This may be naive, but an awful lot of VERY respected venders mentioned on CPF seem to be selling these horrible death traps. It seems to me that they may have more hard data than the average CPFer, and I don't consider their products to be quite as lethal as web rumor/anecdote seem to believe.
That being said, lots of "reputable" products have resulted in serious incidents due to deception/ignorance (Toyota, Firestone, Philip Morris, BP, etc)
My question here is like with most chargers when the batt is fully charged and the charger sensors it, doesnt it simply cut off so the batts dont heat up and overcharge ?
now this is somehow cofusing :crazy:. we are hearing 2 different messages here about the charger blinking green while charging. Some say it is normal and others say there is something wrong.
Can somebody kindly help to remove the confusion :confused:
Thank you all for the good info
There are several different versions of the WF-139 and each version behaves somewhat differently so depending on which version a person has, they describe a different behavior and opinion as to how good the charger is. I don't have any of them but from what I have read, the most recent version is quite decent (in contrast to the earlier versions which didn't fully terminate and frequently tended to overcharge) and as pointed out by Oldxx above, the most recent version cuts off the power when the batteries are fully charged unlike the earlier versions.
Now as for the blinking , well as it gets closer to fully charging the battery it starts to blink green , and when its done , its a solid greeen .
The closer it gets to being done , the faster the blinking .
FWIW... both of my WF-139 chargers are ~2 years old at least. I bought them from DX, about a year apart.
-Unloaded the LED is green
-Load cell, LED turns red and blinks green
-Blinks once every ~second
-LED turns solid green when charge reaches ~4.18V
-Charge terminates at at that time and there is no trickle charge current
I do not know how it behaves with protected cells, I only have unprotected cells.
i have just reveived my wf139 and UF protected batteries from DX. i've already ordered a voltimeter but it hasn't arrived yet so i cant say the state of my brand new batteries. i just put them to charge, but my charger DOES NOT FLASH GREEN. it flashes only RED. i saw everybody saying it should flash red and green. is it ok?
Most likely your charger is fine, but your batteries are crap.
Learned that myself, the hard way. Sometimes Ultrafire cells don't work properly with the Ultrafire WF-139 charger. My AW brand cells work just fine with my Ultrafire charger. I encountered the same problem you did with my first batch of Ultrafire cells. Switched over to using AW cells, and no more problems.
ive just brought the wf139, mine does the same with aw 18650 cells, flashes red when charging then solid green when finished. i think this is normal. perhaps ultrafire have changed it on the new models to not do the green and red flash
