coppertrail
- Joined
- May 21, 2006
- Messages
- 920
I've had the Ultrafire WF-138 for about 2 weeks now. I charged a couple Ultrafire 3.6V 14500 cells last week and the cells terminated charge at 4.29V. I did a top off charge on one of these cells this evening with the same end of charge voltage.
In a thread under the Ultrafire WF-139 charger, folks are reporting the same results with non-protected cells.
It seems as though these chargers are designed to cut off at 4.29V. From what I've read on batteryuniversity.com, this is "pushing the limits" with LiIon cells. According to the Charging Lithium Cells article, venting can occur at voltages above 4.3V, which could be dangerous. It also appears that the life cycle of these cells will be reduced by charging to 4.29V. Another member mentioned that he removes the cells when they hit 4.2V.
These cells work great, even at these voltages, in the Jetbeam MKII and MKIIx lights. They still regulate at this voltage.
As it stands, I'm happy with this charger and cells, but disappointed that the life cycle of the cells will suffer at these voltages. The cells don't become even "slightly warm" to the touch, which is also reassuring.
