Ultrafire wf-500 reflector question
kyhunter1
South East KY
I have a Ultrafire WF-500 flashlight with a lumens factory 630 lumen lamp in it, and two AW18650's. My reflector is OP. Can you get a smooth reflector for this light? If not, are there any CPFers that polish reflectors to a smooth mirror finish themselves? My light set up really rocks, it is blazing bright. I would like for it to throw better, and I really need a smooth reflector for this. Any ideas?
I'm in the process of getting this setup as well. I've read in some other posts that if you screw the bulb further into the reflector, it creates a tighter hotspot. You'll need to remove the o-ring from the bulb for this... appearantly this increases throw 15-20% over the stock bulb. :whistle: .. thats if you havent already tried this...
Will have to give it a try. I have the Lumens factory lamp instead of the stock one. Either way, this is still one awesome light.
Just tried it... It made my light more floody, and a larger less intense hot spot. That would = less throw. I put the o-ring back in.
Are there any one on the forum that could take my OP reflector and polish it to a smooth mirror finish?
You could possibly experiment, get another reflector and some polishing compound. But i don't know where a person could find some special polishing compound. Maybe someone else knows?
I don't think you'll have any luck polishing it smooth, the coatings are very thin and very fragile. But no harm in trying I guess, Lighthound can sell you a replacement if you ruin it.
I just had a thought, Is it possible to fit another deeper reflector in here... that would give more throw?... even with a different bulb type with be interesting :thinking:
hmmm Maybe something from the magmod stable can be applied here, because the wf-500 has about the same sized reflector as a mag if im not mistaken :thinking: . I wouldnt go the hotwire route because this is going to be a practical walking light for me, and 2 x 18650 IMR's wouldnt give much runtime with a veryyy high powered bulb. Though Im new to incands .. maybe somebody more knowledgable can suggest something :shrug:
