D
**DONOTDELETE**
Guest
Hi all... got a question for you guys/gals.
I am the proud new owner of an Ultrastinger
, and I want to modify it somewhat..
So here's the plan. I want to stick Streamlight's 20 watt bulb in there instead of the 10 watt stock bulb. Logically, it should be quite a bit brighter, right??
I also want to get a replacement stick of sub-c 2400mah batteries, (are there higher cap NiCads out there??) the kind used in high-performance R/C cars. This should keep the runtime from dropping off too drastically (I'm thinking around 45-50 min with the brighter bulb). Have any of you tried it yet? I heard second hand from a very technical-guru friend of mine that he could rig a charger for the new stick(s) that would completely recharge in 8 minutes
. Sweet!! Do you folks have any recommendations? Opinions? Smart Remarks? All are more than welcome
. Thanks in advance for your help.
