Um, what kind of lithium chemistry do I have?
jzmtl
Montreal, Canada
So I bought a set of ultralast 3.0v 700mah lithium ion cells (2 cells and smart charger for $15). I don't think they are protected because there's no claim about it. I always assumed they are the 3.7v lithium cobalt oxide with a 3.0v circuit like those tenergy cells, but when I looked at them I don't think they are.
Email to manufacturer went unanswered :)rolleyes:). Here is what I have. The charger claim puts out 3.6v 360 ma (DMM measured 3.7), cell hot off the charger measured 3.3v. Could these be lithium iron phosphate? I didn't expect them to be consider how cheap they are, and also I thought iron phosphate is 3.6v.
So I'm lost, what do I have here?
You can see the pack on first page of this pdf: http://nabcorp.com/pdf/ul_photolithium.pdf
Definitely not Li-Ion. They would measure 3.7-4.2v+ open circuit, and 3.0-3.2v under load if they were the protected, bucked Li-Ion cells.
It says li-ion right here on the cell wrapper, and they work fine in my 123a lights. So what the heck do I have here. :confused:
They are definately rechargeable, I've topped them off many times and I know others who have used them for a while with no complains.
Hmm, very well could be. 3.2v nominal, check. Charger puts out 3.6v, check. His is 500mah and mine is 700mah, so either aw has protection circuit or the manufactuer just pulled a number out of their behind.
As I understand, a 3.7V cell with voltage regulation circuitry will measure something to the effect of 3.8V open circuit. If you are measuring only 3.7V at the charger, there is a very good chance these are LiFeP04 or something similar. There isn't much price difference between these chemistries anyways, so it's possible.
I recall the 500mah rated batteries (AW's LiFePO4 I think) are supposed to outlast the so called 700-750mah rated batteries. I think someone got carried away with the 700+ ratings.
