koala said:
Hi MrAl,
Many thanks for running the simulation and sharing the results. I appreciate it.
I had to read the 2nd paragraph in post #14 many times and finally understand.
Sorry I am not very good at this, I know how a boost and buck circuit works but
this is difficult to master. I came home from work late tonight, dead tired.
It does take some time, but it's not impossible.
koala said:
Anyways, it's all cool after a coffee and beaming the wall. So the capacitance
in the schottky acts as a bucket. We'll need to fill up the bucket before the
water can flow. And water has to be dumped and wasted to before the next flow.
All right so the lower the capacitance the better? Look for a diode with lower
capacitance or lower the switching frequency? In this case, the Zetex switching
frequency is determined by the Vout and Vin.
Yes lower capacitance would be better, but the Zetex 2000 diode looks ok with it's 50pf.
at the frequencies we intend to run.
koala said:
Assuming single AA cell 1.2v input and output of 3.4v, the onTime 3.116uS and
offTime 1.7uS(fixed). That's about 208kHz operating frequency. For 2xAA cell the
switching frequency is 320kHz. Your memory is all good MrAl
Ha ha, i remembered something
koala said:
In the post #13, I mention the reverse current is between 160uA and 300uA. Unfortunately,
That's for 1 diode not 4. Which is a problem when parallel, worst case 300uA x5, that's
1.5mA? Is it included in the 1.5% efficiency gain in 3rd paragraph, post #14?
Yes except it's a loss, not a gain. 1.5ma means 1.5 percent lost,
300ua means 0.3 percent lost, etc.
After reviewing this information however i realized that the transistor
wont be 'on' all the time, so the loss will be greater when the
transistor is on and less when the transistor is off, because the
voltage across the diode changes levels. With a 66 percent duty
cycle the loss would be around 1.1 percent rather than 1.5 percent,
but no need to calculate this accurately because this
is the loss caused only by the reverse leakage, and we are
assuming worst case. In an actual circuit we could end up seeing
only a 0.5 percent loss.
The simulations take this parameter into account, but again they
assume worst case, so perhaps we could see 3.5 percent overall.
koala said:
So to counter the internal capacitance problem, is to parallel less diode as possible,
otherwise the increase in capacitance will defeat the purpose of a lower forward voltage
diode. Use 2-3 parallel instead of 5 right? Suddenly, with all these variables, it
seems not so worthy to have parallel diodes in exchange for the 2-3% in efficiency.
That's the long and the short of it, but it mainly depends on if
the decrease in forward voltage causes enough gain to *more* than
make up for the loss due to capacitance. In other words, one is
a gain and one is a loss, and the net sum tells us if this is
favorable or not to our circuit. With higher output voltages,
the decrease in drop will not make as much of a difference as
when working as low as 4v, so we might end up with a total net
*loss* if the output is higher. Lucky we are at 4v where we
see a little gain.
You lose some, you win some, and some get rained out.
In our case, we lose some, gain some, and the net gain is not as
large as we would like to see, but then again at least we got a gain
so we can say we accomplished something positive
koala said:
I haven't got the chance to do the forward voltage test yet, will do it.
Getting late now, got to :sleepy:
Ok, have a good night.
Oh BTW, the diode models i used for the simulation to get an overall idea how
much gain or loss using four in parallel had all of the parameters that
would affect efficiency so yeah we can guess around 3 percent gain
with four in parallel. I ended up with four instead of five cause it was a
bit easier to manage, and four is probably enough anyway.
