not very smart
- Joined
- Aug 30, 2010
- Messages
- 2
hello all, i want to make underwater light for the bottom of my boat, i'll be maching aluminum "pots" to put them in with cooling fins machined on the back to dissapate heat, i'll encapsulate the electronics in a clear resin and be done. however.....i'm "electriclly challenged" and have no experence in how to wire these things. my boat is 12 volt with a large battery bank, power consumption is not an issue. my research so far has lead me to the CREE 3 UP XP-G R5. AND A BUCK DRIVER. i plan on making an array of these in each pot...maybe 7 of the 3 up units per array. question is this...do i need anything other than buck driver and leds? or do i just put 12v to driver, then wire driver to led?and if i understand my research so far i will need 1 buck driver per 3 up led. oh of forgot...i plan on using 1000ma drivers. do i have this right? next question...is there a simple way to incorparate a temp sensor fo some kind to prevent overheating should i forget to turn them off when i trailer the boat? thanks in advance!!
