prayzrofGod
- Joined
- Jun 5, 2008
- Messages
- 13
Hey CPFers.:wave:
I'm currently making a 4 MC-E mod of a WP-800 from DX. I'm mostly just upgrading the XR-Es to MC-Es and changing out the driver board. It's currently planned to be a 4s4p rig with either 2x 18650 or 4x rc123s depending on the driver I end up using.
At this point I've removed the old leds, mounted the new ones, and wired them up. When I tried to test the mounts, I found that DDing the 4 MC-Es with an adequate voltage leaves one of the MC-Es not lighting up. I figured it was a short or a bad led so I dropped the voltage and tested each led individually. All MC-Es light up the night.
With these encouraging results (I now know that all MC-Es work), I tried all 4 again. Yet again the 4th MC-E in series refuses to light up and the other 3 aren't at full power. That tells me it should be a short so I tested each of the combinations of connectors starting with the legs of the malfunctioning MC-E and moving out at each connection point.
All legs, solder joints, and wires work without problem. The only time that the MC-E shorts is when I send the voltage through another led. I've checked for wires touching the heatsink, the mcpcbs, or other joints.
I've gone so far as to remove all the leds and remount them. It seems to be the same board, not a specific led.
PLEASE HELP ME!! I am sure this is a SIMPLE issue, but I'm at a complete loss for a fix. Any advice would be greatly appreciated.
