Hello Frosty,
I was afraid you would say that...
There has been a problem with some batches of the 2500 mAh cells. The problem cells develop a high rate of self discharge. They work very well, right off the charger, but can be completely discharged in a week or two.
I would suggest that you charge them up, measure their voltage, then let them sit for a week or so. Measure the voltage again and you will get an idea of how well they are holding up to self discharge.
I consider those as higher capacity cells, but think you should try them and see what you find out. They may work very well for you. With the 2500 cells, it seems that some of them work well and handle abuse better than others.
In a Mag85, you will get better performance (brighter, whiter light) from the Titanium Power Max 1800 mAh cells, but will loose some runtime.
Tom
