Hi there,
I usually just hack away on these stress relieving mods but, I think I'll ask for some assistance on this one.
I just received my CR2 Ion today & decided to open it up as planned. I intended to put a warm binned Cree in here & the slightly off-center emitter on the ion should be justification enough for the surgery (okay, it's off maybe just by a hair of a millimeter)
Here are a few of the picts with the bezel off the head.
The reflector is one piece with the threaded head.
Here's a shot of the driver side after I removed the retaining ring & foam donut.
Any pointers on how to remove the guts from someone who's already done it? If not then, I'll eventually just attempt to get them by fashioning something to grasp that board with the hole & yank/torque the sucker. But for now, I'll be a little more patient with this one & wait for some suggestions. With the retaining ring setup, the internals feel like it's just pressed in but :shrug:
Oh yeah & after I put it back together I did put a CR2 in there to fire it up for the first time
-AZ
EDIT: Completed this mod awhile back. I don't usually post my mods but, seeing the lack of Cree XP-E posts -> I thought I might as well this one time. Special thanks for Derek (datiled) for mentioning the slight height increase when using a xr-e for this mod. Instead of living with the increased height of the pill, I gave the diminutive XP-E a try.
Sorry for the so-so pic.
Hard to say to compare to the original output (b/c I had it on for so little time) but, the XP-E creates a much throwier beam (& of course brighter.)
I might still go back to my original plan & install the warmer XR-E Q3 5A in there as I much prefer the warmer tints (That & the fact that a pin prick in my XP-E's dome creates an artifact in the beam that I don't care for:shrug
Thanks for looking.
-AZ
EDIT#2 Here's a quick beamshot snapped at a slight angle to wall @ about 1meter. The ion is on low. Notice, the very slight halo around the spot. This is due to how the XP-E was focused in this particular reflector. It's not a product of the emitter itself. On high, the halo disappears. I intend to get my hands on more XP-Es for future mods. I've found beam angle to be quite similiar to XREs & think they should provide a smooth beam in existing cree XRE reflectors.
-AZ
Thanks for looking.
-AZ
