I believe that the PT Solo is the same as the PT Matrix and PT Quest, which I have. If so, go to Sears and get the Sears Craftman PR drop-in. Good for 1.5-8 volts. About $15. My reflectors are textured. Very floody beam, with a somewhat soft hot spot. I tend to like a fairly floody beam in a headllamp, so it works well for me. Haven't had it long enough to really check out throw (probably not real great in this particular application, although pretty bright), runtime, or heat buildup. Works the same in my PT 20 and PT 40, because the reflectors are the same. PT 40 brighter because the voltage is higher. In other PR bulb flashlights seems to work best with textured reflectors or focusable flashlights. In non-focusable, smooth reflectors, results vary. Some good. Some not. I think it's worth checking out. I like it so far. Hope this helps.
