Sold/Expired $urefire C head 1x26500 & 2x26500
Status
Not open for further replies.
BelliR6
:paypal:
#14 (2x26500) = 65
#15 (1x26500) = 58
Shipping to CONUS = 6
Paypal fee 6%
Total = 134.16:grin2:
Eric242
[-Mad in Germany-]
Guys, how about some pictures of your setups?
I am seriously interested in those bodies but I am not quite sure what to attach to it. I was thinking a M3 head (with a Surefire C/M adapter from a KL3) and a Lumen Factory LA.
Eric
ElectronGuru
Oregon
Here's a good one from Justin Case:
Jay T
Eric
With a stock D26 Head, I thinks it looks a little strange with that lil head.
So I installed a Cabelas / GP mini turbo head with a Lumens factory HO-R5. And I think it looks a lot better.
Eric242
[-Mad in Germany-]
Thanks for the pictures. The 6P head indeed doesn´t look too good. I prefer the head to be at least a littler bigger in it´s diameter than the body. The turbo heads look great on those bodies!
Eric
cernobila
Adelaide, Australia
Eric
You can always get the LF Seraph D36 head and the IMR-9L lamp, works great.
Chodes
Australia
I only have 1 spare head so for now a very simple combo - Malkoff M60 with1 of the old Aw C cells, no clicky just a twisty.
I had a thought , should be fairly easy to turn a cheap solarforce head into a Mag C adapter...
cenz
Hong Kong, China
Hi Chodes,
How is your C cell "twisty" tail-cap, how do you do that?
Chodes
Australia
Hi Chodes,
About 2/3rds of a Mag C spring (the bottom 2/3rds!) It just sits loose on the mclicky adapter but does not have much room to move to cause any problems. It would be fairly easy to permanently attach to the clicky adapter if you wanted to.
FM advised somewhere in this sales thread that a slighlty modified C spring would allow twisty function.
lctorana
Melbourne, Australia
I have McClickies on order from Lighthound, but am using my 1x26500 as a twisty in the meantime.
Easy-peasy.
You just unscrew the switch retaining plate, install a spring from a broken cheap 3AAA torch (you all have one) and screw down the plate back over the spring.
The torch only makes contact at the rim, so backing the tailcap a quarter-turn turns it off.
A temporary twisty.
cenz
Hong Kong, China
thanks lctorana and Chodes!
I found a local spring shop, there are many types / shapes of spring and cheap.
Justin Case
The top flashlight uses a Black KT1, AW Turbo Tower with a 4P MC-E and a GD1000 driver, and 2xAccupower C NiMH cells. I picked the GD1000 driver because it gives me the flexibility also to run with 3xNiMH or 1xLi-ion in full regulation (I have a 3-C cell FM body if I want to use 3xNiMH). Also, the body is FM's first iteration of his C cell, SF head and tail threaded bodies. It doesn't fit the IMR C cells.
The middle light uses an HA KT1, AW Turbo Tower with an SSC P4 U2SWOH-bin and an SOB1000, and 2xIMR26500.
The bottom light uses an SF anti-roll bezel, Malkoff M30, and 1xIMR26500.
fivemega
California
I was more concerned about the switch as the previous version was not very resistant to water entry
Just to clarify that these are water resistance and not water proof and/or submesible.
This IMR version have different switch cover which is seatting deeper/tighter in tail cap groove so is more reliable to stop water drops and moisture into flashlight body.
QtrHorse
Texas
To be honest, I don't know how you get the rubber switch cover out for the tail. It seems like it is in there good.
Fivemega;
How do you get the rubber switch boot cover out if it needs to be changed?
Status
