Hey there guys, absolutely wonderful resource you provide to the world with this community.
I'm in the process of selecting cells and protection schemes for a custom made battery pack; not for a light but for a similar constant high drain situation. At the moment I have a couple options for cells and I'm trying to figure out how feasible each type are.
The cell is made up of two 18650's discharging at 7.4. It's used in a portable vaporizer called the Arizer Solo. This device uses a lot of power and gets rather hot so I want to make sure I have everything taken care of on the protection side to prevent any issues. It's using a standard tenergy pack right now with two 2200 mah cells. I want to improve on the performance it's getting right now with a better set of batteries.
I'm looking at:
callies kustoms 3100 mah unprotected 18650
AW IMR 2200 mah 18650
AW 3100 mah protected 18650
What I would like to do is use the unprotected 18650 callies kustoms along with a PCB to make the cell. Unfortunately they use USPS and they won't carry LiIon cells. I'm hoping they will FedEx the batteries to me but because of that I want to look into the AW cells.
I'd be buying genuine AW cells off of AW's thread in the CPF Marketplace so I'm not worried about that; but I'm wondering how safe it is to use independently protected cells in a pack together. And if I do this; is it going to cause issues if I add another protection circuit to it? Or is that necessary to ensure safety?
If it turns out it is not a good idea to use the protected cells, and I cannot get Callie's cells, I will then probably end up using the IMR's. In this case, will a protection circuit be necessary? I know the cells on their own don't need PCB's but what is the deal in series?
Sorry to drop so many questions in one post, and sorry if I seem like I'm rambling. I really do love this forum!
Thanks,
Michael
I'm looking at:
Thanks,
Michael
