Using UnProtected Cells in a High Drain Flashlight
chip100t
On a single cell flashlight with:
- a protection circuit, you can run you unprotected cells without worrying too much
- no protection circuit, you'll have to remove your batteries, to check the voltage
As for multi cells flashlights : don't put unprotected cells in there!!
Why no multi cell flashlights, I have this light that uses two unprotected 21700 cells. Should I be worried. D1B84E72-935D-4962-9527-61849AA1901D.png
Atmar
Philippines
I think the problem is these cells when they over discharge are not stable
When there is 2 and they are unbalanced it causes reverse charging and they can explode
vicv
Southern Ontario
Meh, you're fine in multi cell flashlights. Check your cells once in a while. If they always discharge at the same or close to the same rate, they're fine. Everyone should have a DMM
vicv
Southern Ontario
Do you mean you actually fried the LED? That is very unlikely but it in no way is determined by whether it's a protected cell or not
