I remember green coated neon bulbs, but they were not very bright
I remember seeing a article in a science book about running one of those edison base neon bulbs connected to ONE door-bell battery and thinking "whats wrong with this picture ?"
I also remember how many times in electronics class when my fellow classmates would try powering up the neon bulb WITHOUT the ballast resistor
Here is a weird piece of trivia, the "negative" resistance in a neon bulb is caused by the LIGHT that it makes making the neon gas inside conduct at a lower voltage
You can test this by biasing a neon bulb SLIGHTLY below its firing voltage, and then shining a light on the tube, it will fire - I have heard of applications that used neon bulbs as gamma-ray detectors
