Thanks Sean, it was awesome of you and will always be cherished..........more than any other mod simply down to the fact its from you!:grouphug:
The crown is just something else, i love them, simplicity, nice top fill design( i mean now all others that are bottom filled are just an inconvenience).
I really will say get a v3 crius, its actually the best fill i have experienced, the flavour is crazy! and of a similar size to the crown. The juice adjuster is novelty but a good idea if using PG or VG , either way mine is fully open and the only flooding i get is flavour
So airy(or not if close up for a tighter draw), right now it is close to perfection with the best of the crown/tfv4 /dripper in one. Hard to explain other than when ready for a change get one.
The tfv4 and crown are still the best tanks available imo, and now the v3 too. I love the base, how easy is this to work with! And using one high and opposite post low, line up well with coil legs. Much prefer the small grub screws too, just feels better to tighten with. Under the posts note the well that leads to the hole on the outer part. This is simplicity at its best, so effective as the wick is pushed down and through the hole. This stops leaks and great for soaking juice up. IMHO its the best overall design yet........ I just cant find fault with the base other than of course , if bigger it would be even easier. Compared to the UD efforts its far better........
