Will check it out later, cheers for the heads up.
Could not hold out and primed the triple Clapton, filled tank with Heisenberg and left for 10
mins or so. Well usually from the off I am not impressed , straight away nice flavour and cloud at 30w to bed in. Now at 40-45w, very little cotton taste from the supplied cotton. Very impressed !!!! Would say on the strong side of hits and flavour production , clouds moderate to high. Impressed ......hell yeh :laughing:
Wicking was not as bad as it looks, 1" cut off the long cotton piece supplied then cut again down the middle
lenght ways. Has to be very tightly wound to aid feeding through the claptons . Then gentle back and forth to open up and fill the coil. Pushed into well ends which meet with the next coil on the base. Concerns would be making new coils and fitting them, looks a bit tricky tbh but that hopefully will be a while off!!!
So for around £6 delivered and with a pre made Clapton coil in with that cost, a bargain and back on the tfv4 again for now. Might be a tad too much for daily use, will have to see. Either way will rotate it with the awesome crius and crown .
Slight leak which seems to have been from the 1st fill up and subsided now, not 100% confident it won't weak again, not enough right now to open up and re-wick
My wick rather than design, do like the way it's designed however and how the wick end meets in the wells, simple, clever , works!!!
The simple part may change come time of making and fitting new coils :laughing: for the cost though and how long coils tend to last, probably worth buying a few of these anyway
and using as a disposable item. Should get many uses/re-wicks before coils give in!
A strong recommend for anyone with a tfv4 tank!
