vinhnguyen54
- Joined
- Sep 14, 2010
- Messages
- 25,613
vinhnguyen54 D26/P60 XP-E2 & XP-G2 Drop In NEUTRAL XP-G2 Available
Need an XP-E2 or XP-G2 Drop in? Order here!
$42 per drop in
Any mode or drive current you want. But below are some drivers and mode options.
Multi-Mode High Current & Low Voltage option: 2.7-4.5V max
A: Last mode memory B: No mode memory
1) LowLow, Medium, High, LowLow, Medium, High, 10Hz Strobe, 2HZ Blink, SOS, Beacon
2) High, Medium, LowLow, High, Medium, LowLow, 10Hz Strobe, 2HZ Blink, SOS, Beacon
3) High, Medium
4) High, 10hz Strobe
5) Medium, High, 2hz Blink
6) High, Medium, 2Hz Blink
7) LowLowt, Medium, High
8) High, Medium, LowLow
1 Mode High Voltage & Low Current : 3-18V - Regulated Single Mode pull 1.5-2.2A Not the brightest options has a big voltage range. Same brightness with 1 li-ion, 2 li-ion 3 li-ion, or 4 li-ion.
Multi-Mode High Current and Medium Voltage: 2.8-6V
- Low-Medium-High with memory
- Low-High with memory
- Low-Medium-High-SOS-Strobe with memory
- Low-High-Strobe with memory
1 Mode High Current and Medium Voltage: 2.8-6V
Solder Fill: FREE
Paypal: [email protected]
FREE SHIPPING WORLDWIDE
$42 per drop in
3) High, Medium
- LowLow 50mA so its a good usable low
- Medium = 35% power so it’s good for normal use
- High = 100% the current power you choose
- The driver Operates from 2.5-4.5V
- Under 2.8V the output will automatically reduce to 35% and blink once a minute
- 1x Li-ion or 3xNiHM only. 2*CR123 or 2*Li-ion = Poof= Dead Drive/LED
Solder Fill: FREE
