I have a project that is effectively done, but I have a power supply question to take it the extra step.
I moved recently and have plans on making a work bench... somehow plans of making an LED desk-mounted work light came first. I basically threw together most of the decent LED's I had on hand that I thought might be bright enough, and just wired things together from there without much planning. At the very least, I mounted it into an old incandescent desk light, so it does look ok for now.
I have 3 banks of 3 different LED's. the components are as follows (and all LED's are wired in parallel, each with a dedicated 1/4W series resistor):
(8) 5050 RGB LED's, 60mA max, running at >40, (I fused the neg/pos of each of the 3 chips because I wasn't going to be mixing colors at all, and I still haven't figured out SMD soldering), wired with two 22 ohm resistors in series
(4) 9mm Strawhat LED's, 120 mA max, running at 90mA (If I had used only these, I would have been happy, but I only had 4), wired with a 100 and 22 ohm resistor in parallel
(8) 4.8mm Strawhat LED's, 20mA max, running at 16mA, wired with a 100 ohm resistor
Old cell phone power supply: regulated 5V, 1A max. With all LED's lit up, I'm using just under 500 mA.
All LED's have a 120 degree beam angle. Some of the SMD's blew one of their three chips during soldering (which is why I cut their current down by just over a third), and one of them just never lit up again after I wired in the resistors (which is why I like parallel circuits with dedicated resistors). I arranged the resistors on a separate board and sandwiched the two together, passing half of the LED leads through to the resistors. The three banks of LED's have separate positive wires, as I plan on having a switch for each one. I also plan on putting a big potentiometer on it for good measure.
Now here's where I'm stuck. I originally was going to wire this with a 12V power supply, which turned out to be dead. After I had finished wiring everything together, I realized that having it underpowered somewhat and running on 5V, I could easily get away with connecting it to 4 AA's and making it portable. I then thought that if I made a little box for it to be attached to that would act as a counterweight, I might as well wire it up to work on a range of different battery voltages (preferably up to 12 or even 24VDC) and have everything sitting neatly away in the box. We get power outages fairly often, and where my girlfriend works it's pretty much routine. They could always use an extra emergency light.
First I thought I'd just make a bank of plugs. Each would be wired to a different resistor to limit a specified voltage over 5V, and you'd just plug some battery terminals into them. Unfortunately, once I start getting up around 7.5V, I need 1/2 Watt resistors, and at 12V I start needing 1W resistors. Since the LED's have 1/4W resistors for the 5V wall supply sandwiched between a a board and some silicone right behind them, I didn't want them to start overheating. They might be ok since they're only limiting about 20% of the power at 12V input, but I don't really want to risk it.
So now I'm wondering about just making a 5V regulated circuit. Can anyone help point me in the direction of which I should choose and why? I have one LM317T on hand, and pretty much everything else to make a basic regulator (I've been looking at datasheets). My only problem with it is that it would limit the mid-range option of battery supplies, since the 317 would need at least 6V input to put out 5V. I wouldn't be able to drain lower voltage battery banks enough to really call this an emergency light.
The other circuit I was looking at is just a zener diode and resitor hooked up before the load. I think it still needs the input voltage to be a volt higher than the output voltage, but I think would consume less energy than the 317.
Any thoughts on how I might configure a supply? I'm still not above having to make a few different supplies for different input voltages (the box IS a counterweight, after all). Some of the key voltages I would input are 6, 7.5, 9, 11.1, 12, 14.8, and possibly 24. after the PSU their will be a dimmer pot and then 3 on/off switches for each bank of LED's.
Any help would be appreciated. Next project I have lined up, I'm just throwing DynaOhms in and forgetting about resistors and voltage regulation altogether.
*Edit: Here are some photos http://s204.photobucket.com/albums/bb274/eapellow/LED Desk Light/
