Sold/Expired Wanted: Textured Drop In Reflector For Huntlight FT01 Cree
TJZ
Ohio, USA
EDIT/UPDATE:
Hunlight has just made a drop-in replacement Orange Peel/Textured
Reflector for these lights.
If a Mod reads this post, delete it. Thanks
Tom
I need a drop in reflector (Orange Peel/Textured) for my
Huntlight FT01PJ XR-E Cree P4.
If not, how about a drop in (Orange Peel/Textured) reflector for a
Huntlight FT01 and I'll modify the hole for the Cree LED
and adjust the reflector height if needed.
I much prefer the above if possible...
Measurements with Digital Composite Caliper:
- Top of reflector diameter 26.5mm O.D.
- Bottom of reflector diameter 23mm O.D.
- Total Height 23.5mm
- Thickness 1.6 mm
I did try McGizmo with no luck. Here is the response.
Hi I have no idea if any of my reflector designs would
work in this application.
My reflectors are available from the shoppe.
- Don
Since not everybody, probably including McGizmo, have a Huntlight with cree it would be helpfull if you posted the measurements of the stock reflector.
