WANTED!!! The owner of KOWALSKI SPEED 50W halogen light
Arthur_
Gdynia, Poland
Hi everyone!
I'm urgently looking for someone who owns a/m light. Mine just broke down and I need identification of some electronic parts.
Please help !
lucca brassi
Kocevje , Slovenia, Europe
I deduce from the picture ( so I'm not sure 100% )
it is ''shunt'' low ohmic wire resistor for current sensing in range under 1 ohm / 2 W (2 W size i have to look my storage )
P=U*I ; 50W = 12V* 4,16A
from size of resistor P=I**2*R ;R= 2 VA /17,3 AA = 0,11 Ohm/2W what is more close to 0,1Ohm/2W
which is close to that http://si.farnell.com/rcd-resistors-coils-delaylines/210-r100-fbw/resistor-wirewound-0-1-ohm-2w-1/dp/1130552
but it is IMO good to swap FET too
PS: have that light build in also charger ? power diodes...end etc
Arthur_
Gdynia, Poland
Wow! Thanks, that's a really nice answer :))
So I will try and repalce with 2W/0,1 Ohm resistor first and see what happens.
I've already swapped FET, and checked power diodes - seems ok for now.
I have a set of new ones in case something is wrong.
If there is built in charger - I don't know. There are some power diodes, but there is also an external charger.
I'll let You know if I succeded :))
lucca brassi
it is maybe better if you put resistor with slightly higher power maybe 0,1 ohm / 5W .
I think that was resistor wire bent and being pinched , therefore, it is blown.
if resistance is too low and then also voltage fall on resistor is to low (0,416 V@ 4,16A ) then maybe fet at 100% would not be open
full in that way you must slightly rise resistance ( but for safe lower is better )
Arthur_
Gdynia, Poland
Hello! I've contacted Kowalski service in Germany and they told me, that the resistor is 0,18R 2,5W :)). After replacing nothing happened - the light didn't work. After spending some time looking on circuit board I've found one broken track !!!! I've repaired it and now everything works!! Thanks for all suggestions!!
