garilla
My brother gave me a Sealed Lead Acid (SLA) battery 12v which was used in emergency lighting in buildings so you can get out in case of power failure. 7.5Ah battery so figured I should put it to good use. At a garage sale found 2 MR16 track lights real cheap. I had this 3/4" shelf board lying around in the basement turns out it was made of Cherry wood. So off to the table saw and sliced it up, made a couple of joints and produced the box for the battery. I should have taken pictures while making it, hindsight is so clear. Anyways threw in a switch made a handle out of a metal clamp bracket and encased that in wood for a better feel.
The heads swivel up down and a little left and right. I purposely didn't do a good sanding job so that it had an old look to it, notice the burn marks from the
router on the rounded edges.
I rubbed in some boiled linseed oil for that old oil finish look. A 10watt MR11 and a 20watt MR16 bulb, the MR11 was streched a bit to fit the MR16 bulb holder and I used a paperclip to hold it in hehehehe.
All flood light but really lights up the backyard really good, nice warm incan light, I have to take some outdoor shots still yet. Yeah I know one light is white and the other is black, I'll get around to making the other black!
I have since added in a charging port on the side so I don't have to take apart the light to charge up. I used one of those computer power supply inputs that uses one of those reverse looking power cords.
I have since oiled up my outdoor table with teak oil, how does it look?
indoor in my basement on my light green colored walls, now the light has 2 20watt MR16 bulbs. I think I'll throw on another head for the 10watt bulb with an independant switch for long runtimes.
And the shop area lit up
Outdoor shots
Outdoor shots
