"1. Usual way - oven soldering. But thats quite a stressful for leds."
Not so much, if done per specifications.
"2. NanoBond with NanoFoil: . . . "
Odd that they compare their process with reflow while they compare thermal conductivity with adhesive (worse than any kind of soldering). And, how would you possibly pass an electric pulse thru an electrically isolated thermal pad?
For hobbyist and small production runs, here is a simple and inexpensive way to approximate oven soldering with good control:
1) get an old skillet made from thick aluminium
2) get a cheap (~$15) electronic oven thermometer
3) get some large metal tweezers, needle nose pliers, etc.
4) attach the thermometer probe to the skillet, inside on the flat area
5) place the skillet on your kitchen stove or other controllable heat source
6) slowly bring the skillet to soldering temperature as specified by the board and LED manufacturers
7) place the circuit board in the skillet
8) apply any kind of solder you want
9) position the LED(s) on the solder
10) observe wetting within the specified time limit
11) carefully remove the assembly to cool
This seems simpler than simultaneously positioning the LED and preforms while applying pressure and electricity, no?
