WEAPON MOUNTED LIGHT that can also make a good handheld (T25C2 T6?)
SettleNow
LOOKING FOR A GOOD WEAPON MOUNTED LIGHT. WOULD LIKE NEUTRAL COLOR. EAGLETAC T25C2 T6 LOOKS LIKE EXCELLENT EFFICIENCY, PLENTY BRIGHT.
EITHER ON LINE OR IN PERSON IN SOUTH FLORIDA. ILLUMINATIONGEAR.COM WAS RECOMMENDED TO ME
2) Budget: An easy question, but you may change your mind after answering the rest! :)
LESS IS BETTER BUT IF I NEED IT TO WORK I NEED IT TO WORK...
____I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
WEAPON MOUNTABLE BUT NICE IF IT IS A GOOD HANDHELD THAT COULD BE PUT IN HEADBAND
____I am not sure, please help me decide.
X____I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
X____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
SMALL-MEDIUM
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
OPEN TO SUGGESTIONS
____LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
OPEN TO SUGGESTIONS. I DON'T WANT TO RELY ON MY OWN HANDINESS WITH HAVING TO ALTER IT IF I CAN AVOID IT.
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
PREFER IF CAN USE RECHARGEABLE OR DISPOSABLE
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
X___I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
PROBABLY OVER 300 LUMENS WITH OPTION FOR LESS, BUT OPEN TO SUGGESTIONS
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
MIX -- WIDE THROW? OPEN TO SUGGESTIONS.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
MIX 5M -- LONGER
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I am searching from a helicopter)
90 MINUTES PLUS
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
CRITICAL. PROBABLY NEVER NEEDED, BUT IF NEEDED, NEEDED.
____Not Important (A "night-stand" light).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
PROBABLY REMOTE PLUS CLICKY BUT OPEN TO SUGGESTIONS.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
PROBABLY A VERY BRIGHT MODE AND ONE OR MORE LOWER ONES PLUS A STROBE. INSTANT ON/OFF WITHOUT HAVING TO CYCLE THROUGH MODES WOULD BE GOOD. OPEN TO SUGGESTIONS.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
X____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ---...--- emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
TI SOUNDS GOOD BUT OPEN TO SUGGESTIONS
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
X____IPX7 (Waterproof to 1 meter/30min)
X____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
IN HOUSE, LONG STANDBY POSSIBLE BUT WILL RECHARGE AS NEEDED.
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
THANK YOU FOR ANY SUGGESTIONS.
gsr
Utah
Look at Elzetta, Surefire, and Streamlight, for mounts, handheld lights, and dedicated weapon lights.
