WF-500 was a real popular flashlight a while back, 500lm for $25 incan bargain.
With 2x18650, it's a bit too long for my liking, however, it has a nice rare option to
Run 2x18500 instead. Here is a size comp. vs. Mag 1D 1185 & kel-lite 2C ROP Hi. with the WF-500 in 18500 shorty mode.
Only 6.5" tall.
It fits in hand perfectly like Mag 1C, with bezel diameter same as mag as well.
The Stock light has a hot spot as bright as ROP Hi, just a bit smaller & it's not as bright as mag1185.
The only flaw is that it draws ~3A & needs double click to turn on even with AW 18500.
The hot spot is also not perfectly round, kind of egg shaped, which bothers me a little bit,
as I am pretty picky about white wall beam quality.
My mod is simply to fit in a 5xCree LED module that's only recently become available.
Fit in perfectly. The heat transfer was limited to just the top of the reflector where it's screwed into the bezel.
So I wrapped around a bunch of aluminum wires to make body contact between the reflector & the head.
It gets pretty hot after 5 min on high, but stablized, so I think it should be fine to run non stop.
The light with the 5xcree module is incredibly bright. I made quite a few direct drive P7, none of them come even close to this. I am estimating close to 1000 lumen, the hot spot is smaller than p7 & it's quite a thrower.
It's as bright as my mag 1185 but with a smaller hot spot, it throw just as far as 1185 if not further.
The beautiful pure white bean is more pleasant than the P7 mags I've owned. Here are some beam shorts.
(I found some P7 has different tints on each die, causing a hot spot with ring slightly different color)
The tints of each cree in this module are identical, making the hot spot flawless.
Overall, I am glad I re-visited the WF-500, this is a real winner over p7 mag shorty, both from cost,
lumen and beam quality angle. I am a bit surprised as how bright this have turned out.
It also only take one click to turn on, module comes with 5 mode va. original incan single mode.
A real winner in my book.
Only 6.5" tall.
