M
MrGearaholic
Hi All,
Not long ago I got an EagleTac D25C xm-l in neutral white. I thought it would be a good vampire light to drain the last juice out of my cr123a's with its low setting of 0.5 lumens. However, I noticed that even with this moonlight mode the light quickly died using a cell that still gave me 2.89 volts (without load). This same cell still gives me a higher output of around 2 lumens (I guess) in my NiteCore Extreme R2, for quite some time now already...
So I don't get it: what is it exactly, that determines how long a light keeps running on low? I naively thought that lights with lower lumen lows should run longer than lights with relatively higher lumen lows.
Is it the xm-l that needs a higher power than the r2, therefore asking a higher current (even on moonlight)? I can imagine that such a higher current makes the voltage under load drop faster. Or is it the operating voltage, the electronics, the efficiency of the emitter, or...??
I'm pretty new to this matter, so maybe some of you experts here can explain what the key factor is?
Thanks!
Sent from my iPad using Tapatalk HD
Thanks!
