Hello Gene,
I'm sorry, I think I misread your initial post. Let me try again…
Gene said:
I noticed awhile back that CR123 cells were exploding with almost weekly frequency here on CPF. I'm sure Newbie's posts helped to quell some of them with all his warnings of the dangers using them. However, you would think there would still be a couple now and then since a lot of us are still using multiple new cells without checking their voltage or condition without using expensive instruments.
I'm curious since the explosions were a very common occurrence just a few months ago. I haven't noticed a single explosion since all the reports that had folks in panic selling off their multiple celled 123 lights in droves just a little while back.
To my knowledge, there have only been less than 10 incidents (if memory serves me correctly) involving CR123 cells. I can only recall 7 of them, but there may have been a few more.
We came up with the theory that the cells must have been mismatched to get this to happen. NewBie decided to put this theory to the test and refined the "recipe" for getting a CR123 made in China cell to rapidly vent with flame. The "weekly frequency" of cells exploding was the results of his controlled testing.
It may have seemed like a "common occurrence," because he did a lot of tests and supplied video documentation along with his temperature and voltage results. He was conducting the tests outside, because of the fumes released during failure, and when the ambient temperature dropped, he was unable to get them to go off. However, it is not very common at all.
Some of the conclusions from his tests indicate:
Off brand cells are more prone to this problem. He was unable to get any of the name brand cells to fail under the same conditions that the other cells failed at.
Cells need to be mismatched by around 15%.
A lot of the incidents occurred after the lamp went off while the circuit was still connected.
A continuous run is needed to heat the cells up to the proper temperature to sustain the failure.
Roughly a 1C current was needed to get the cells to warm up enough to fail.
Warm ambient conditions were also needed to get the cells to fail.
Cells in the open don't fail. They need to be contained in an enclosure of some type to keep the cell temperatures up.
ZTS matched cells did not fail, however some new cells that were ZTS mismatched also did not fail.
Multi cell LED lights do not have a safety problem with mismatched cells.
Single cell lights do not have a safety problem.
On top of this, a bad batch of Titanium CR123 cells was discovered, and BatteryStation started doing ZTS testing on all of their cells. The Titanium cells were pulled from stock. Since BatteryStation started ZTS testing all of the cells, and a new batch of Titanium cells is now being shipped, there have been no further "incidents," but it is also a lot cooler than it was in the middle of last summer.
Add to this the raised "awareness" that it is possible that something could possibly go wrong and a few simple steps on how to avoid problems and we expect problems to go away.
Gene said:
Wonderful responses by all but I'm still asking why there has not been AT LEAST a couple more explosions since this panic began and we went through the latter part of last summer without one? I know it's colder now but should we still be terrified? Should we still sell off our multiple celled 123 lights in droves?
I was unaware of any "panic." I would suggest that if you are prone to panic, you should panic about driving your car. Using your flashlight is most likely "safer" than driving…
Tom
