T
thiswayup
- Joined
- Jan 29, 2007
- Messages
- 172
You might want to try a green/turquoise. There's tons of posts about the difference, but I think it boils down to -- it takes less turq light for the same amount of definition that red gives, but gives better detail and color perception. So about the same disturbance of night vision.
There is some controversy, but the standard view is to disagree:
http://www.flashlightreviews.com/qa/nightvision.htm
The back of our eye, called the "retina" detects light and allows us to "see". The retina is made of of 2 types of structures, cones and rods.
The cones are responsible for our normal daytime vision. Cones detect both the wavelength (color) and intensity (brightness) of light that goes into our eyes and passes that information to our brain.
The rods are responsible for our "night adapted vision". Rods do not detect wavelength (no color), but are very sensitive to intensity (brightness) of light. They pass on only shades of gray to our brain. They only work at very low light intensities (dim light), are most sensitive to light at about 500nm (turquoise/cyan), and are blind to red light (around 620nm).
When our eyes are fully night adapted, we are using our rods. The rods cannot detect red light, but our cones can. So if we use a red light flashlight we can see what is around us using our cones. The rods in our eye can't see the red light and our night adapted vision is unaffected. Turn off the red light and you can go right back to looking at the stars in the same detail as before without having to wait another 1/2 hour for our rods to work again....
But you said our rods are most sensitive to Cyan light! Can't I use a Cyan LED light to look around and still preserve my night vision?
Yes, our rods are most sensitive to 500nm (cyan/turquoise) light. Remember though, that the rods are very, very, very sensitive to intensity. A bright light of any color (except red) will ruin your night adapted vision. So cyan is actually the WORST to use when you need a brighter light to see the environment around you since this light wavelength is what the rods pick up best. Cyan light has to be kept very, very dim to keep it from ruining night adapted vision.
Alternate view:
http://stlplaces.com/night_vision_red_myth/
http://www.astromax.org/kniffen2.htm
