What is best: L-AA, L91, Alkaline or rechargeable?
Commander
Denmark (It is a Country)
Hi CPF!
<font color="green"> I need your help! </font>
Here is the case:
I’ll bee attending an army curse with excessive light restrictions. The only light allowed is the Mini Mag light. To get the best out of this situation I am looking at the Tektite LT-1 LED (it looks similar to the original led).
Here is the problem:
The LT-1 is only specified for 3V and the L91 I normally use (with NewBeam) is 3,4V.
Can I use batterystations L-AA or is a rechargeable battery better?
This is what I need:
1: Compatibility
2: Reliability
3: Long burn time
4: Cold weather tolerant
(Price is of no concern)
Regards
Commander
will you be around a ability to charge it?
just HOW cold ?
i think i would go with a lithium, long lasting, works in all kindsa weather, and not rechargable. no fuss no muss, be there when you needed it. especially if you like demolitions 🙂
what kind of run time VS Light output do you desire?
There are some great posts by silverfox above with test results for exactly what you are asking. - Alkaline Shoot out and rechargeable shoot out.
In quick overview terms
- All of the 2 x AA setups will run 2.5 - 3 volts under load
- At the current draws you are looking at (less than 1 amp), the L91 AA cells will be the best performing for run time under your stated conditions.
Re: What is best: L-AA, L91, Alkaline or rechargea
You could always be sneaky and put a resistor in the tailcap to drop any excess voltage that lithium AAs would put out. It could be made to be removable also. I *think* there are also some resistors switch tailcaps out there you can buy that fit mags also.
