What is the best single AA LED Driver?
Status
Not open for further replies.
ake
Central NY
Hi,
Could someone let me know or point me to the link that provides the brightest and most effective single AA LED driver?
I am lookling for something that is as bright as ARC AAA and the longest possible run time.
I did use the search but find nothing. So if someone can let me know where it is I would really appreciate. I will delete the thread if I find it dupplicated to other topic.
BTY will ZTX300 circuit works? It seems to comsume a lot of juice for LS driver at 300mA with 2AA. What would be the runtime of this circuit if Iout is only around 25-30mA?
Has anyone test the run time on the circuit provide in the ZTX300 doc.?
Thanks,
Ake
There are many circuits that will boost from a single AA cell to drive a single Nichia type LED at 20mA.
The ZLT+ testing I did a while back showed poor efficiency stepping up and driving 4 LEDs in series (77%). The data sheet reference design for max brightness shows at 1.5V efficiency of 84% and 77% at 1V input.
I just ran some numbers through for the MAXIM 1675 and with Vin 2.3V and Iout 20mA I measured an efficiency of 87%. With Vin 1.5V and 1.3V Efficiency was 86%. With Vin of .8V efficiency was 79%. This particular board and IC was still delivery output down to 0.2V Vin. The LED is not very bright and I don't measure any Iout (<1mA). Vout is 2.47V under this condition.
If I change the inductor to a low loss version the efficiency numbers would go up another 2-3% more.
These may not be the "best" 1 AA cell driver to drive a single LED.
Status
