What is the difference between magnetic and usb charger?
Lynx_Arc
Well-known member
Tulsa,OK
Depends on the charge rate, likely the direct connect USB would be faster especially if it is USB C.
Lynx_Arc
Well-known member
Tulsa,OK
No. It's just a different connection. If using the same power supply
I'm sorry I was thinking of wireless which uses coils, if there is a mechanical connection of contacts then there is no difference in power other than perhaps contacts getting corroded somehow which is equally possible with wired connections IMO.
vicv
Well-known member
Southern Ontario
Yeah I presume that he was talking about magnetic charging and flashlights which usually just uses a magnetic electrical contact.
One thing I should point out also in your post is talking about USBC. Unfortunately USB-C is just a connector and it does not imply any type of charging specification. It was supposed to. That was the reason it was created. But unfortunately many things that use that port do not use proper USB-C specifications
Lynx_Arc
Well-known member
Tulsa,OK
Yeah also there is no specified charge rate either can be from 1A to 3A and even include fast charging protocols up to 20V even.
vicv
Well-known member
Southern Ontario
Ya that's spec. There's also Qualcomm qc 2.0 and 3.0 that can use a C connector on one end. Or one plus dash charge. Hauwei fast charge which is 10v 4A. Then for data it can be usv 2.0 to 3.2. Something else which was supposed to be universal and it was screwed up for proprietary reasons. Google is using it to spec. So is apple for their MacBook chargers
