Re: What is the focal length of your Aspheric lens?
Edit:
Reading again this old post from me, from before the big crash. I think I had not totally clear the difference between lumen and candela.
For throw that's more then cleared up in the thread Calculating throw.
For Lumen I still
want to find out how to predict lumen for given distance led-to-lens, by a given led, and a given lens.
Please help where you can, with explanation.
Losses in the system:
1-Lenses with shorter focal lengths have smaller aperture. Not the whole lens diameter is effective.
You can test to see what is the back focal length and the effective aperture.
2-There are losses from reflections, light emitted from the led is partly reflected instead of transmitted.
I THINK the graph Geometric correction factor takes this in account to show losses.
3-The viewing angle of the led doesn't match the aperture in our application.
Easy to calculate if you make a construction of angles and diameters in cad-software or on paper.
4-Not all lumen are distributed equal over all viewingangle of the led.
Needs mathematical integrating, or my preference; measuring area from graph led viewingangle.
Crosscheck with JTR's White led lumen test.
5-There are losses in the glass, each plane, just pick 85% for plastic, 90% for glass and 95% for AR-glass.
Can be refined later from manufacturers specs.
6-Lumen emitted from the led can be estimated by led datasheet at given current, Vf and temperature.
Crosscheck with several reviews and JTR's White led lumen test.
7-Lumen OTF = 1 x 2 x 3 x 4 x 6 ?
Can be checked with integrated sphere measurements from aspheric flashlights.
Edit2:
Did some calculations and I think there are a few flaws.
- Unsure about the graph, have to check that first. And the graph shows shift between lens and mirror. Could this be for reflectivity of the material or for the focal versus back focal length?
- Is it valid to measure a surface from the led-graph to have the correct lumen figure for that viewingangle?
Not sure yet. Some contradiction to figures from JTR White led lumen tests. The led might show different behaviour when overdriven also.
So, I will have to make measurements with a lightbox to make my own table that shows how many lumen from the led are transmitted at different focal distances.
