What is the slimmest CR123 single cell light?
Paul6ppca
RI
Looking at my edc line up,I like the size of cr123 lights and I am looking for the slimmest one currently available.My slimmest if Fenix PD 10, 19 mm or .74 inch. My Sunwayman v10 is 23.2mm or .91.Which is noticible larger in a pocket. So what is the slimmest CR123 single cell light?
UI ,open to ideas
bightness, current led standards, would prefer approx 200 lumens.
primary or RCR is ok
UI ,open to ideas
The Fenix PD20 is pretty darn thin and small all over.
Surefire E's: 1"
BC10, BC20: .91"
PD20, PD30: .85"
T1A, mini123, Nautilus: .8"
D25C, D25C2: .79"
E15: .78"
PD10, EZ123, Logan: .75"
OP in what respect are you looking to upgrade the pd10 (or just looking to add something new to the rotation)? Because it's already among the slimmest 123's you'll find, & pretty close to 200 lumens. I'd have one myself it were just a little longer.
Looking at my edc line up,I like the size of cr123 lights and I am looking for the slimmest one currently available. My slimmest if Fenix PD 10, 19 mm or .74 inch. My Sunwayman v10 is 23.2mm or .91. Which is noticible larger in a pocket. So what is the slimmest CR123 single cell light?
Since the CR123A cell is 17mm itself, if you add a millimeter on each side for (acceptably durable) battery tube walls, 19mm diameter would be about the practical limit. I don't have a PD10, but would have suggested a Peak Logan as similarly thin, and close to as thin as one could reasonably get....
UI ,open to ideas
Quark Mini X.
