I hate having to twist & click. unless its a twist only UI. then i'd think just twist it to desired level would be best.
If i had to make a UI without completely copying ZL the dream would look like this:
--Press+hold while off = moonlight, for XX delay then slowly ramps up
--double tap anytime = max
--press when off = last mode memory - OR - preset to a configured level (chosen in a special config setup)
--press+hold while on = light level (if @ max ramps down, if under 5% ramp up) if in middle ramp up (OR down (configs setup)) quick ramp, [quick blink off@max for notify], quick pause, then ramp down quickly,[short low flash @lowest for notify], pause, ramp back up slower, repeat. If you were just ramping in last 3 seconds another press+hold will change directions and move at the slower ramp rate. In case you missed your level, or if just wanted to go a different direction.
--- you could configure in setup:
whether to ramp up or down on initial press+hold
memory or preset level after first ON click.
high and low ramping speeds
maybe even delay times for press and hold, and delay times before ramping start in the other direction @ max/min
maybe replace ramping levels with a choice of 3 to 8 well thought out presets. for people who would rather have preset modes than dynamic ramp.
Any thoughts?
my vote is for Zerbalight!! but I'm so used to it. perfect amount if quick hold delays for changing levels. any level of light easily accessed. - which is -
--press + quick release = max.(or programmed high)
--press+short hold = programmed low mode (low or moonlight)
--continued hold goes from low to programmed medium (which is still super quick to get to medium)
--then the double click for the second level in whatever mode your at. sound complicated but its great!!
I found this thread cuz I like the Olight S10 UI - which is -
-last mode memory (excluding tac strobe)
-its press and hold goes to moonlight. but moonlight is a memory mode 🙁 so you lose whatever memory you had before
-double press while on goes straight to tac stobe. which is awesome, but i'd like double press to go to max.
-while on, press+hold to cycle through levels
-- so the only problem is after i use moonlight i have to press and hold for awhile to get to max again. if the double press went to max instead of strobe it'd be perfect UI
-- the hold cycling time it too long for me. it is not incredibly long, its just not zebralight fast.
But, i know that the zebralight ui is tough for my father in law to handle, and that random people that'd pickup my SC600 would tend to MAX it right away. sometime they get moonlight and not even know its on.
