What is your favorite UI in a light?
What is your favorite UI / switching method?
  • Total voters
    286
I like the Zebralight. Short press for high, long press for low.
Since using it as a bedside light, I find that my other lights with moonlight are too bright! I use either the lowest or 2nd lowest moonlight modes on the Zebralight. Lowest is very dim, but good enough to see not to bump into anything, or find a glass of water, etc.
I like Quark Pro UIs. The UI itself is nothing to write home about having 6 modes to cycle through, including a couple blinkies, but it has a great work-around "feature" of a single-handed momentary-max from ON (ie, any lower mode in use). Works just like a car's high beam flashers, and with plenty of finesse to signal a fast Morse Code. Ideal bump-in-the-dark UI for me, and I frequently use it to spot my dog off-leash, signal cars that pedestrians are ahead, find the next trail marker, etc.
I like, and can appreciate, most other UIs I have come across - the only one that has me really scratching my head is a forward clicky as the only controller for a multi-mode light.
I am satisfied with 2 modes on my lights 95% of the time so the Quark Tactical is my favorite. Just set the modes you want for tight and loose head and its just second nature to operate. I need to be able to feel my light and know what mode its going to come on in and the Tactical gives me that.
Yes, I think it is a good UI, but it would be better if they put those blinkies on the "head tight" position along with the strobe already there. Or hide them out of the way somewhere!
+1 My Quark tactical is the light I use outdoors most often, because I don't need access to moonlight. Two modes is good enough.
Honestly almost any UI out there is pretty good if fitted to the right type of light. But I'm a big fan of rear mounted forward switch with a tight/loose head selector or control ring. Armyteks programmable UI is about the best I've found due to the sheer customization available. Also the ZL interface is about the best EDC UI I've used, with the Quark Tactical being another great one.
Hello. My name is mike and of course I go by horizonearth on most all the sites I frequent.
In any case, I have several led lights (torches?), but my favorite is the Fenix L1T version 2. Mine was rebranded for leatherman and was called an LGX-200.
It has a forward clicky switch in the tail and by rotating the bezel it goes from hi (approx98 lumens I think) to low beam (around 16 lumen I think.)
No strobe or SOS modes, very simple. I like the simplicity. When I first go 'into LED's' I wanted something with more whistles and bells, something that would blind an intruder at 100 yards. However, after actually using the flashlight on a daily basis, I found it extremely useful and grew to love the UI.
Please forgive me, I realize this is more information than you were looking for, but as you can tell, I really like this one.
Mike
#1 Magnetic ring, for sure
#2 Twisty head
#3 everything else 😀 I don't really like any other method
Depends on where I am
I think a story is needed to justify an interface preference. Mine is this. I was headed outside at about 11:30pm to pee and have a smoke. Hangin on my shirt was a Zebra H52 on moonlight so I could see where I was going. In my pocket was a Olight s15 and a Nitecore SRT3. I was also going to do a little beam and output comparison. Heading towards the bushes, in near dark because the Zebra was on moonlight, I lit the cig and then took a step out of the circle of light that I was in. All of a sudden, there was a loud grunting, scared the crap out of me. Reached for the Olight, the damned butt cap was loosened to prevent the dreaded battery drain from light on in pocket problem. :hairpull: As I'm back peddling towards the door i grab my SRT and twist the ring to high, forgot to push the back switch. ohh. I'm at the door and grab two of the lights that I keep right there. 501b's , one red and the other with a 300+lm drop in. Click on the red to see whats looking at me, 2 sets, waist high... not deer, kind of running back and forth across the lawn. Click on the white, light up the yard and see nothing else, but hear something in the woods. Close the door, take a breath and decide right there that a two motion light is not good. I go inside to pee and take a freaking breath( alot by now, it was pretty scary). In the morning, I find out that the loud grunting was Mama bear, tracks were 25 feet from where I was. I'm now looking for a BRIGHT clicky, easy to use in a panicky situation. Thinking of taking the pill from my S15 and putting it in my E1e. But a 1 button interface to on is best for me. Thanks for reading.
Good story Zingers - highlights what is important in a light's UI - is it simple under duress?
I think on one hand some UI's are just objectionally better than another.
At the same time other UI's are better for one person because that is what they are used to and super familiar with. For example on the old fashioned bar phones where T9 predictive texts was the latest technology I loved Nokia and hated Samsung. I realized that Nokia wasn't better - it just was what I was used to.
You mentioned using 3 flashlights with very different UI's - and none of them good for a duress situation.
Magnetic infinite adjustment ring with detents and a forward clicky or electronic clicky
Re: Depends on where I am
...Heading towards the bushes, in near dark because the Zebra was on moonlight, I lit the cig and then took a step out of the circle of light that I was in. All of a sudden, there was a loud grunting, scared the crap out of me. Reached for the ...
One of the reasons I love having a single-handed momentary max from ON... moonlight > 800 lumens in a millisecond (and back to ML, or whatever low mode was in use) with a small 14500 pocket EDC light.
Which light is that reppans? I love the idea of having a 4 position tail cap... don't know if that is feasible/possible. Off/momentary/on/jump to max when pressed extra hard.
I'll throw out there that my far and away favorite UI in a light is combined with the worst mode sequence and cheesy tail cap and I've been searching to find a modder to fix that!
Seriously - I'd probably pay $600 for this $100 light if someone could fine tune the details. As it is, I wouldn't give more than $40 for it.
The thrunight scorpion/lynx - Supbeam T10.
I loved how easy it was to operate one handed. Once I got used to it it was so easy to hold and switch modes nearly instantly with my thumb in the most natural position turning the adjuster wheel. It made every other UI I have including control rings seems so clunkly and akward by comparison.
My lambda light I can sort of adjust with one hand without thinking about it.
All the other control ring lights I have I have to readjust my grip and think about it to change modes one handed but the scorpion - no grip adjustment, no thought going into it, no straining, just naturally turning the wheel on the back to easily go thru the modes.
BUT the mode sequence is asinine and the switch so cheesey.
Starting from all the way counter clockwise you have:
1.) a half baked lock out that sometimes works, sometimes doesn't, often the wheel gets stuck here. Best to avoid.
2.) Low*
3.) Firefly
4.) Strobe
5.) momentary max
Or if you were thinking in numbers it goes: Junk, 4,1,spaz,10. A really unique idea I have for ordering 5 well spaced modes would be something like: 1,2,3,4,5.
But for excitement Thrunite likes: 3,1,5,2,4 😀
I work for an NGO doing relief work in war/disaster areas and I'm often in hot combat zones. I think firefly is one of the most useful/helpful modes. When in the jungle at night in the pitch black but you need to see something firefly is almost always more than enough but hopefully not too much when your life depends on keeping your position/presence secret. (Long before multi mode flashlights and "firefly" mode SF/recon guys always depend on it - you just do something different like use the back light from your watch to read a map - many guys still do those kind of things and when they see a light with firefly mode they get envious!)
The scorpion puts firefly right next to strobe making it too dangerous to attempt to use at night. You can be fairly confident you'll get max when you want it as long as the wheel didn't get stuck in the lock position and you mistakenly thought it was all the way clockwise.
So I guess what I'm saying is I'm really looking for ALL of the above:
1. A great UI system
2. A logical/intuitive sequencing of the modes
3. Well spaced modes.
I know all of us have different needs/desires so my hope would be to find a light close enough to what I was looking for and then have a modder take it from there.
Add to that the switch comes on insanely easy when your fingertips brush over it - so the batteries are usually dead.
Keep in mind this is a work-around "feature" - clicky. I understand Surefire makes a dual stage clicky that will do the same, but sadly I don't do CR123 lights. I personally dislike momentary from OFF clickies, and have swapped reverse clickies onto my tactical UI lights.
My favorite UI is still the good old two-stage UI of the SF A2 and McGizmo's old piston drive flashlights - unfortunately, it is a dead breed and lives on only in the drawers and pockets of flashlight nerds worldwide such as me.
