i dont want a prototype or custom machined parts...
All i want is a schematic i can give to a company to produce for me... All the companies said all they need is a computer schematic for them to produce.
I dont need anyone to find me the materials or components... they are LEDs and resistors readily available from many places. There are no custom components that need any type of firmware or debugging...
Its 3 LEDs...with 3 resistors... on an aluminum core circuit board with a transistor and a diode plus a positive and negative.
If you can honestly tell me that would take 10 hours let alone 20... i think theres a problem.
And i guess im in the wrong business if your making $5000 minimum per customer... A 40 hour work week your making $10000 which means your telling me you make $2,080,000 a year? I wish i was you.
Everyone has different rates. I charge nothing to design and prototype, but only if I'm going to build and sell the production units (which is where I make up for the "free" services). For design work only, it's $75 an hour, no minimum. For assembly work, I aim for $30 to $40 an hour, although that's not written in stone. Don't know if these rates are too high or too low based on my skills, I just know it's a heck of lot more than the $3 to $10 an hour I'd make right now working for others, so I'm happy with them.
It sounds to me that by "computer schematic" you mean you need the circuit board laid out on CAD software so a PCB house can make the boards from gerber files. For that to be done, you need to know the specific parts you're going to use (each part has a different pad layout), the size the circuit board needs to be to fit in whatever enclosure you put it in, where, how many, and what gauge wires are connected, and so forth. This can easily take 10 hours once you count phones calls, emails, getting familiar with the project, etc. I'd say it would take me anywhere from 10 to 20 hours. I probably spent 30 hours revising and laying out a 2 amp automotive LED driver even though I already knew which parts I was using and how they were connected. It's really easy to screw up a PCB layout unless you're very careful. Do that and you're stuck with potentially thousands of dollars worth of useless boards. So in the scheme of things the $1500 isn't totally unreasonable for this sort of thing. If you can get anyone other than a friend to do it for less than $500 I'd be very surprised. People who can do this sort of work don't exactly grow on trees.
BTW, $10000 a week equals $520,000 annually. Great money to be sure, just most who charge the hourly rates mentioned here rarely get 40 hours per week. If I average 5 hours weekly over the course of the year it's a lot. This year has been a bit busier so far. Unfortunately, a lot of the compensation is "deferred" (i.e. for a project which I won't see any money from until my customer creates a market).
If all you're looking for is an electronic schematic to drive a few LEDs from 12V, then here's one for free:
It's a linear circuit so you'll need to heat sink Q2 if you're driving power LEDs. Also, you'll need to use a power transistor (something like a TIP31) for Q2 instead of the small signal PN2222A shown on the schematic. And R1 needs to be a different value (the circuit as shown will only drive the LEDs at 20 mA).
