If you want to stick with Fenix, there is the new L1T V2.0 that runs off 1 AA. It is a simple 2 level(High/Low), and can be set to turn on at either level. It is also activated by a forward tactical clicky so you can use it either momentary or constant on. If you order from
David at Fenix-Store.com you can get 8% off your order by using CPF8 coupon code at checkout. He also has free world wide shipping. $42.78 shipped. Specs and description for this light...
The Fenix L1T V2.0 takes the simple yet effective interface of the LxT-series and upgrades the light with a more efficient emitter for a brighter, more intense beam. Also new is a textured reflector, eliminating artifacts and dark spots some smooth reflectors can create. The L1T V2.0 still retains the ability to select between high and low beam with a simple twist of the head, allowing the user to select the best compromise between brightness and runtime. The L1T V2.0 compromises nothing and is still built tough to last.
Features:
• Utilizes a Luxeon Rebel LED with a life of 50,000 hours
Two levels of output, changing by turning the bezel (patent)
• Current regulation
• The high level: 90 Lumens, 1.5 hours (Ni-HM)
• The low level:
Constant 15 Lumens, 15 hours (Ni-HM)
• Uses one 1.5V AA ( Alkaline, Ni-MH, Lithium ) battery (not included), inexpensive and widely available
• 9.4cm (L) x 2.1cm (D)
• Made of aircraft grade aluminum
• Durable Type III hard anodized finish
• 45-gram weight (excluding batteries)
• Waterproof to IPX-8 Standards
• Toughened ultra clear glass lens with AR coating
• Tailcap switch with tactical 'momentary-on' function
• Textured reflector for a flawless beam
• Battery not included
• Includes a holster, a lanyard, two spare o-rings, and an extra rubber switch boot
Then there is the light I would highly recommend for a duty light. The Surefire L1. I like it for the rugged feel. The knurling is like none other I have felt, that is except for my other Surefire's. It is like velcro that attaches itself to your hand. The engineering and machining that goes into this thing is just simply amazing. I love the simplicity of the switch with its two levels of either momentary or constant on. The size is perfect for either pocket, lanyard, or holster carry. It has good run time for a single cell cr123a light. The output is just amazing, and equals the output of my 120P. Although I don't like to abuse my lights, I feel this little gem could take a lot of abuse and just keep on trucking with no problem. And, if it does ever have a problem, Surefire backs it up with one of the best lifetime warranty's in the industry. I highly recommend this light....Not only as an EDC, but as a tool that you will be able to depend on for years to come. With the cpf2006 discount code, you can have this light for $128.25 shipped with 8 free batteries from
MattK at batteryjunction.com.
