What lights use 17670 batteries?
Windscale said:
Many SF lights use them, including my old style 6P.
I put one in my U2, works great. Is it true that the U2 loses some output when you use a 17670?
They won't fit in my P3D :shrug:
luigi said:
Among the ones I have:
Surefire L4 and Fenix P3D
Luigi
Fenix P3D? I tried inserting one(17670) in my colleagues (P3D), it doesn't fit. Is this a 4rd party body/modded? TQ
[/b]
I remember seeing test data for these used in the L4, and the data showed that there was a slight loss in output, but the numbers were still so close, you'd have to be a robot (with light meter) to notice. I'd think it'd be the same for the U2.
here's most of the 1x17670 incandecent options.. from the chart DM51 linked to.
Cell configuration: 1x17670
Body Options: (3.7V 26mm lamps, refer to complete chart for more configuration details)
Leefbody 1x18650 w/C tail and head, +SF compatible tail-cap/bezel. +++
Surefire G2, 6P, C2, Z2, G2Z, M2. +++
Wolf-Eyes 6 series sniper (non-turbo). +++
DX "JALL" ++
Ultrafire/Superfire 2 cell: WF501B, WF502B, ++(some rare UF heads don't fit LF lamps)
Cabellas XPG 6V 2 cell +++
G&P 6P, T-6 +++
Brinkman Maxfire LX +++ (requires removal of built in reflector, lamps don't seat perfectly centered)
Pila GL2 ++
Huntlight FT-01 +
Pelican M6 new version only +
Body Options: (D36 lamp)
Wolf-Eyes 6 series explorer (with turbohead) +++
Ans here the 2x17670 options
Cell configuration: 2x17670
Body Options: (with 9V 26mm lamps, refer to complete chart for more information)
Leefbody 2x18650 w/C tail and head, +SF compatible tail-cap/bezel. +++
Surefire [G2, 6P, C2, Z2, G2Z, M2] +TWO 1 cell extenders ++(some extenders fit 17mm cells, some don't)
Surefire [G3, 9P, C3] +ONE 1 cell extender ++(some extenders fit 17mm cells, some don't)
Wolf-Eyes 6 series sniper (non-turbo) +ONE LRB-168 extender, + copper wire mod. ++ (requires modification)
Ultrafire/Superfire 4 cell: WF501D, WF502D, ++(some rare UF heads don't fit LF lamps)
Cabellas XPG 12V 4 cell +++
G&P 12P, T-12 +++
Body Options: (SF 9V M series lamps... more details in complete chart)
SF M3T +1 cell extender ++(some extenders fit 17mm cells, some don't)
SF M3 + 1 cell extender, +KT4 ++(some extenders fit 17mm cells, some don't)
SF M4
SF 6P, C2, D2, Z2, M2, (G2?), +TWO 1 cell extenders, +SF turbohead (KT1, KT2) ++(some extenders fit 17mm cells, some don't)
SF 9P, C3, (G3?), + 1 cell extender, +SF turbohead (KT1, KT2) ++(some extenders fit 17mm cells, some don't)
Leefbody 2x18650 w/C tail and head, +SF compatible tail-cap, +KT2 ++
Leefbody 2x18650 w/C tail and M head, + SF compatible tail-cap, +KT4 ++
Body Options: (with G&P 9V mini-turbo style lamps)
Cabelas XPG 12V 4 cell ++
SF 6P, C2, D2, Z2, M2, G2, + 2 1 cell extenders +
SF 9P, C3, G3, + 1 cell extender +(some extenders fit 17mm cells, some don't)
Leefbody 2x18650 w/C tail and head, +SF compatible tail-cap. +
Body Options: (with 9V D36)
Wolf-Eyes M90 Rattlesnake +++
Body Option: (with SF M3 9V style lamps)
SureFire M3 + 1 cell extender ++(some extenders fit 17mm cells, some don't)
Surefire M4 with M3 head/bezel +++
Leefbody 2x18650 M head with M3 head/bezel and SF compatible tailcap +++
should also mention that some of those will take 18650 cells as well, the rest of the chart shows which ones will... but 17670 cell would work fine too, you just get less runtime.
Most 18650 lights should work just fine with a 17670 as well provided it's not drawing very high levels of current.
