What'll come first?
orbital
Well-known member
WI
500,000 CPF members
..........or.............
Genuine 5000 mAh 18650
500 Lumens per Watt LED
PocketLight88
Well-known member
Wisconsin
500 lumens per watt, then 500,000 cpf members.
Unless we discover a new element I don't see 5,000 mah batteries happening [emoji20]
Jomohr84
Well-known member
NW Minnesota
But we are seeing innovation in battery R&D. Gold nanowires, lithium-air breathing batteries, etc. There is a lot of research taking place to make better batteries, so real 5000mah may not even be that great compared to what may be coming soon.
Offgridled
Well-known member
Southern California
Jomohr84
Well-known member
NW Minnesota
I've seen some youtube videos of these water powered engines and it seems legit, so why aren't we all driving water powered cars? I believe it takes a small amount of crude oil to start the engine up, but from there, it is water powered. I know there exists technology to separate the hydrogen atoms in water using electrolysis, creating hydrogen gas, and use it as a fuel. The hydrogen gas can be used to fuel cells in a vehicle for zero emissions. It should be THE energy source of the future IMO.
chillinn
Well-known member
Can't we already squeeze 5000mah out of 18650? Isn't it a question of load, such that the same cell might only be 2100mah in one application, but could get over twice that in another low drain application?
If not, I still vote that 5000mAh 18650 will appear first, becuase you are setting the bar way too high for either CPF membership or lm/W. The answer must be the 18650 5000mAh cell will appear long before even 1000lm/W or 100K CPF members.
orbital
Well-known member
WI
CPF reached 100,000 members about 7 years ago.
membership numbers have absolutely exploded in the last 5 years
btw:: chillinn you are 355,356
ssanasisredna
Well-known member
Given the patent and plans are readily available, perhaps it does not exist because it does not work the way the inventor claims .... and not one has replicated his claimed results. There are claims that may be valid that show 10's of % improvement in efficiency on what are typically low efficiency engines (small gas motors) and this could be attributed to pre-vaporizing the liquid gas using the exhaust gases for a more complete combustion.
All our knowledge shows it takes a fixed amount of energy to split water into oxygen and hydrogen and burning that oxygen and hydrogen can only recover that energy, not add to it. Conservation of energy still applies.
All these magical devices, including the 70MPH carburetor have several things in common, the big one being no one can recreate the "inventors" claims.
ssanasisredna
Well-known member
Active members or just registered users? Registered users, sure.
500LPW .. that's only going to happen in green and that is getting over 80% wall plug efficiency. Since no one has solved efficient green yet, I will say this will come last.
We are still a fair ways away from the theoretically limit for Lithium batteries so I will save 5000mAh in something the volume of an 18650 is pretty much a given. What is not a given is whether 18650 will be around to see it. It seems to be common enough that it may have easily another decade behind it, but with that level of technology?
Hooked on Fenix
Well-known member
500,000 CPF members will come first. Then we'll have 5000 mAh cells, but they'll be 20700 as 18650 will be fading away. Then we'll have 500 lumen/watt l.e.d.s, but they'll be green.
orbital
Well-known member
WI
I hear ya on the battery size increase,
but I'm not buying more lights just because larger batteries are being made ---at least I don't think so :grin2:
Tesla is going 21700
