Frijid
My most bothersome would have to be the one i own now, a 89 s-10. Although, i can't quite fault SOME of the problems it has on itself. I blame some of the problems on the previous owner. for example a MAJOR sludge problem with the oil. Reason this exists is because the guy i bought the truck from, only changed oil he said every 10,000 miles or more, and at that, he used dollar store oil. After i got it, i went ahead and changed the oil, only to break 3 sockets trying to remove the drain bolt on the oil pan. Reason for this was, i found out the guy who owned said that the pan leaked around the bolt, so he "took care of it" by tightening down on the bolt with an air impact wrench. Funny thing was, the only reason it was leaking was because the rubber gasket was gone off the drain bolt. I finally got the bolt off with a pipe wrench, which in turn i had to buy a new bolt (and gasket).
It doesn't burn oil, it EATS oil. In just a 100 mile trip, it takes half a quart. Again, i just take it because of poor maintenance, and miles on the vehicle. (i'll be honest, the engine it has in it, 4.3 or 262 ci, whichever you prefer to go by, isn't known to get a lot of miles). The transmission is shot. It's an automatic, and when sitting on level ground with your foot on the brake and in park, when you move the shifter to D, the transmission makes a loud metallic SNAP, then POW. and when it POW's, the whole truck jerks forward like a snake striking.
Went to start it up about a month ago after leaving the grocery store. It fired up, idled good, then after about 10 seconds, it just died. cranked, and cranked, and cranked and never would start. tested for fire. It was a real weak yellow. let it set overnight, came back the next day and it struggled, but finally started. So i changed the fuel filter, and to no avail, it still is the same thing. every now and then it will just leave you stranded. My first guess was, ignition module, coil, or something in the distributor ( i changed the spark plugs 3 months ago)
Discovered The other day, it now has a major vacuum leak. Got gas, started it up to leave. The fast idle kicked in, yet never did kick out. I noticed what sounded like a snake under the hood hissing, or someone slashing a tire. The idle speed of the engine was fluctuating up and down, almost screaming at times, to make up for the vacuum loss. So i though, ok, i'll just open the hood and stick my head in, and listen for the air leak. simple enough right? well, i open the hood, only to get sprayed in the face by antifreeze, which now is leaking somewhere, and was hitting the fan blade and sprayed me in the face, in my eyes, and even got some in my mouth. Not to mention it was all over the inside of the hood. So i shut it off to find the leak. Can't find it anywhere. after it cooled down, i opened the radiator, and it was still full. The recovery bottle was still full also. Drove it the next day, no leaking antifreeze, and no hissing vacuum. On the way home from town today, it starts leaking antifreeze again. Still can't find the vacuum problem cause it isn't hissing now. I got an estimate on how much to fix EVERYTHING on it, the estimate was around 3500 dollars + labor. Biggest pain for a vehicle i've ever had.
And to think, 6 months ago, i bought an 85 mazda RX-7 off a family member. 147,244 miles on it when i got it. When i sold it, it had 182,119 miles. Only thing that had ever been replaced on it was the battery, tires a few times, spark plugs a few times, oil changes, the water pump once, had the carb rebuilt once, and the alternator changed once. Everything else was still original, including radiator, spark plug wires, transmission etc, even small things like the fuel filter were still original.
After i found out that there wasn't a mechanic anywhere in town who could work on the engine (there wasn't anything wrong with the engine, i just searched around just in case i needed one) and no one in town or anywhere around outside of town knew how to work on rotary engines, plus not needing 2 vehicles. Only thing that i, personally had to buy for it was just some motor oil to add to the engine every now and then (rotary engines are designed to burn oil, it even said so in the owners manual that it's normal for them to burn oil) plus the cost of oil and filter to change every 3,000. well, i sell the car in fear of the price and bothersome of finding a mechanic if i ever need one. so i sell it, make a 500 dollar profit. Well, i called the guy i sold it to exactly 5 hours ago, only to find out now, it's got 210,xxx miles on it, and still going strong. he said he even drove it outta state last week. no problems what so ever.
I sold the best one, and kept the bothersome one!
So anyways, was has been you're best and worst vehicles?
